Hello,
I'm thinking of buying a Skyline. I've owned a few cars before and I like driving enthusiastically (read: track for fun on the weekends).
I have been stuck on R32's for a while and was looking at a 4 door for insurance and space purposes (I'd like to fit a couple of BMXs in the back and still have room for subs and a mate).
My question is - are there any specific issues downsides or advantages that anyone might see with a 4 door r32 over a coupe?
I mean what parts can you assume to be able to use the same as a r32 couple and which parts are specific to the 4 door?
Are parts easy to get? How much heavier is the 4 door? Anyone use them for drift?
Basically to give an idea of what i'd be doing with this car is probably the following (in no particular order)-
suspension - coilovers, swaybars, struts usual stuff.
soft engine/breathing mods - exhaust, muffler, hiflow cat, air filter
I would also like to put in some mild cams later down the track when I can afford a computer as I'm interested in torque more than just boosting and intercooler for KW.
Final question - are the stock exhausts any good? A lot of people get from cat back and say it makes a lot of difference, or is it worth getting extractors as well? (if i did get them it would prolly be in one go).
Lotta questions - any help is appreciated. THANKS!!
https://www.sau.com.au/forums/topic/45356-4-door-gts-t/
basically everything from the behind the front quarter panels is different to the body.
eg: doors, rear seats (i think), boot lid, rear lights, rear bar.
i don't think they are too much heavier, bout 50-100kg (don't quote me on that) if i can remember, also little bit longer and little bit taller.
yes they have been used for drift!!
hope these attached pics inspire u. :cheers:
https://www.sau.com.au/forums/topic/45356-4-door-gts-t/#findComment-924231
the 32 4dr is/was a common drifter in japan.
i dont think there is an extra 100kg in them, but i'm not sure.
the sedan is 15mm (bit over 1%) taller & 50mm (a bit over 1%) longer.
the front ends & wheelbases are the same between sedan & coupe; the extra lenth in the sedan is in the boot & rear section of the roof line.
advantages:
- uncommon in aus so you get a few double takes/comments about having 4 doors
- slightly larger interior, front & back
- easier to get into the back
- larger boot
disadvantages
- coupe has nicer taillights
- most prefer the look of the coupe but overall shape is similar
- body parts probably harder to come by (not sure though)
https://www.sau.com.au/forums/topic/45356-4-door-gts-t/#findComment-924398
That's great - thanks for the response.
So basically the consensus is the driveline etc is all the same? (Just confirming).
Also - was looking at buying an auto because a manual 4 door is hard to find. Does anyone know of any dramas with that ? Other than making room/drilling to add the clutch is everything else bolt in? I mean if getting a gearbox that was in a r32 stock coupe to put in a stock 4door?
PS LOVED THOSE PICS.. OWN! :)
thanks again for the specs - I'm suprised its less than 100kg !
https://www.sau.com.au/forums/topic/45356-4-door-gts-t/#findComment-925728
Thanks very much that site looks great - just a quick question though wheres the HCR fit into this:
http://english.auto.vl.ru/catalog/nissan/skyline/
I'm still a bit confused with the model numbers there heh heh. What are the changes between the model numbers there? heh roughly that is? :)
Thanks again :mad:
https://www.sau.com.au/forums/topic/45356-4-door-gts-t/#findComment-925795
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
