Hey guys
Looking for opinions on paint damage to the roof of my R32 GTR
The car was resprayed in the original colour in Japan and whilst a good finish, the roof has a few spots where there is damage to the paint, under the clear coat.
I have had a quote to respray the whole roof (removing all glass) and fix crazing on some plastics components for $2k. By the time i buy new trim pieces from nissan and pay to remove/refit glass it will be close to $3.5k
Sorry but to the point i was wondering if anyone is aware of any other options other then a full respray of the roof as its isolated to a few areas only. Im also not quite sure what paint damage it is.
Here are some pics:
Cheers Jase
Edited by gts25
https://www.sau.com.au/forums/topic/453566-opinions-on-r32-gtr-paint-damage/
no real options, you cant get away with a fade out on a roof. if the job wasnt done properly and there is damage under the clear then its a strip back and repaint. if its not done properly then your gonna end up back in the same position
Haha I'm sure it won't be the last time you open your wallet for the GTR. Unfortunately most peoples wallets are continuously open while owning a GTR, including mine.
Just make sure the people fixing the paint strip it right back otherwise the problems might arise again in the future. Some shops will just scuff the paint back and spray over the top unfortunately.
  • 4 weeks later...
Hello! I don't think it can be fixed in other way than repainting. I had such problems with my car too. I had to repaint the whole roof. Then I applied a colour protector from colourshield, and everything has been OK with it so far. Hope, I will never have to do it again...
Edited by trevordd
I have been back to the panel beater and yep it needs to be resprayed. Roof is going to be stripped right back and resprayed, down the a pillars and the rear quarters. Whilst they have the car I am having all plastic components repsrayed (grille, N1 kit, mirrors, tail lights etc).
Job will be done properly and all glass will come out. The great thing about it is the windscreen guy they use is going to use a generic rubber over the edges and over the front and rear windscreens rather then me forking out $800 for the original trim kits. The screens will be removed, reinstalled and custom rubber install done for <$500
Will be done in the next few months..
  • 8 months later...
hey guys
to wrap this thread up properly, i had my car resprayed last week (roof, rear quarters with glass out and most plastic parts) and picked it up yesterday
it came out fantastic. heres a shot of the roof:
as previously discussed a generic rubber was used out on the outside of the screens instead of the expensive nissan trims kits. in my opinion it looks just as good if not better then the multiple piece trim kit. all up to remove and reinstall glass with genuine inner clips and generic rubber was approx $500.
heres what the rubber looks like
stoked with how the car came out
got the work done at johns twins in wollongong. cant speak highly enough of their work and customer service
terry - unfortunately i was interstate when the work was done so i didnt speak to the windscreen guy. the rubbers look to be of good quality
jase
Edited by gts25
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
