Wrecking R33 Gtr Vspec
Wrecking R33 GTR V-SPEC
Nismo speedo cluster $450
Nismo centre gauges $200
Hks boost gauge $80
Hks temp gauge $80
Brembos front and rear $1500
Mines Ecu $200
Bmc $150
Gearbox pull type $800
Rear seat $200
Front seats SOLD
Grill mint $200
Bonnet with bonnet pins $350
Headlights $350 pair
N1 front bar with lip $500
Front Gaurds $400 pair
Gaurd risers $100 pair
Sideskirts 2 peice $150
Front Reo $150
Rear boot and wing $250
Rear diff v spec $300
Rear drive shafts $150 each
Subframe bracing $150
Tailshaft $100
Air con set up $150
Power steer pump $150
Clutch booster $ 50
Intercooler $100
Standard Intercooler piping $100
Bov set up with recirc $200
Door cards $200 set
Boot trim $100
Drivers window switch $120
Front shafts $50 each
Engine Wiring loom $200
Ignition barrel and locks $150
Rear bar $80
Rolling shell straight good paint no interior no panels track only $1500
Most things available
GOLD COAST BUT CAN POST
0487924497
TEXT FOR PICTURES PLEASE
hello im interested in your door cards if still available, are you able to take pictures for me and close ups please. and maybe wanting lip and front bar . and also would like to enquire about the plastic surrounds that are over and under the steering wheel if you have them.and your engine wiring loom can i have pictures and need as much info about the loom , condition and added extras applied previously , like splicing in to it. the boot trim as well i am interested in mainly the plastic part that runs across the back part of the boot it runs in between the rear lights, but ill will take all the boot trimmings , also radiator rubber grommets for holding the radiator.
Edited by ggs
I've bought a number of parts off this guy with no problem over the last 12 months, but he seems to have gone missing a couple of weeks ago, and hasn't replied to a number of phone calls and SMS's asking if I could call in and grab some parts he said he had, 3 minutes earlier. Not sure what has happened????
 Share
