Japan forum regulars,
Guys, I've just moved house and I won't have ADSL access (40 Mbp/s mind you) for another 2 weeks, so hang back with those 1/24th die cast model orders etc ok?
So it'll be Rezzless around here for awhile... I haven't buggered off, just letting you guys know!!! :cheers:
When I come back I'll have a "Photo Diary" update and I'll sort those model car orders out etc, etc...
p.s. Special thanks goes to Troy (Evil_Pee... I mean "Evo_Lee" :D) for sacrificing his Mitsubishi Evo 5 all day last Saturday during 35 degree heat helping me move house... well done lad, u da man!!!
https://www.sau.com.au/forums/topic/45364-message-from-rezz/
Your welcome Lezzbian...I mean Rezzbian :cheers:
LOL...only the delicate goods and packages went in the Evo, but the Lancer does have a big trunk so it was all good, only needed to make 2 trips. The rest of Justin's funiture went in the removal truck, have to also give a big thanks to removal guys for working 5hours in the atrocious heat and moving all this stuff up 5 flights of stairs to Justin's new place.
If you want to know how hot it was, well we manage to sneak away to the local Super AB mini car show for an hour and this is what 35+ degree heat does to a carbon bonnet...STILLWAY Evo7.
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-924196
Your welcome Lezzbian...I mean Rezzbian ;)
i dont see it. is it twisted/melting?
dont car engines run at temperatures above 35c =)
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-935140
Huh...:confused:
Course carbon can withstand high temperatures before it fails and melts through...but with all material there is a transition state. Carbon will not flex that much under it's own weight, sitting under the sun all day at that temperature the bonnet was obviously starting to droop and flex like rubber.
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-935674
Perhaps it's the angle of the photo. Course CF can withstand high temperatures before it fails and melts through, but with all material there is a transition state. CF bonnets doesn't flex that much under it's own weight, but sitting under the sun all day at that temperature the bonnet was definitely more then 35-37.5 degrees and she was drooping and a little flexy.
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-935773
wtf is T3? 3,000mbp/s? I'm at home... are you? If you are, pat yourself on the back!
Monkey... I'm detecting some kind of competiton or something going on with you... it seems that almost everything I do, you gotta come back and say something to the tune of "I see your ***** and raise you ***** ". I'm not having a rant, but if you wanna annoy/irritate/rev me up, at least make it funny!
3 words dude: I'm not interested...:cheers: now can we get on with the job of producing the best Skyline website on the planet?
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-939980
yeesh, ease up rezz, it was a mildly humoured statement... and no i'm at Uni (hence the T3, see you were supposed to ask how I was on a T3 which i would use as a conversation point to tell you why i was at uni) but anyways, I'll catch ya later on some other thread.
PS did you get my PM about thoses discs?
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-940004
OK, 私はあなたを最近悩ますことを残念に思います。 私は、あなたがチャーミングなユーモアを回復することを望みます。 sock 材料を除外します。 ^__^
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-940054
You did NOT write that yourself did you... the dictionary style language gave it away. But yeah, I'll leave out the sock bizzo :D
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-940847
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
