sometimes, well most of the time i have it flat stick or slight throttle it bounces off the limiter and bogs down, missfires and slowly looses revs and power, its like what happens when your spark plug gap is ****ed...it was doing it with a gap of .8 then i went to a .7 but still does it. if i back off and back on the throttle it will sometimes get better but once it hits the limiter again itll bog down, missfire and loose revs even with foot flat or slightly, its like as if its surging out. this is mainly halfway through a slide (off street). all i want it to do is bounce off the limiter cleanly for peace at mind.
whats a solution? should i close or open gap more or is it something else? timing perhaps? i got no idea
cheers.
https://www.sau.com.au/forums/topic/45365-rb25det-off-limiter-bogging/
The R34 will happily bounce off the rev limiter all day.
It used to be a slow pop pop pop as it hit limiter and then dropped spark then picked up again, but now with the light flywheel, its like a machine gun!
Nice.
Could be coils if it starts happening before you get to the limiter - mine starts misfiring at around 4500, and I don't usually see more than that because it feels terrible.
I understand that the car isn't running properly, but why do you want it to bounce off the limiter? If you're accelerating, hitting the limiter is costing you time, if you're doing a burnout, backing off the throttle a fraction should make bugger-all difference to smoke output, and if you're trying to drift, hitting the limiter generally means that you either have no throttle control or you're doing it wrong.
Learn throttle control - your car will thank you for it, and you'll be a better, quicker driver.
its not that i bounce it off the limiter often, its just the satisfaction that it will run cleanly if need be. all these people are sayin learn throttle control, learn throttle control, when clearly its not about that, i must explain a little better, as SOON as it hit the limiter, no bouncing off it, even without WOT, it still does it, sometimes doesnt even need to hit limiter, it just goes BRRRRR, looses revs and power and sometimes backfires hard. always when its under load.
sorry to confuse the subject but yea im not one of these 'lets just flatten it around a corner' style drivers.
  • 9 years later...
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
