R32 Gtr - Adjustable Fr Camber Arms - Suggestions?
Yes so in order to paint a panel I need to dull out the existing clear coat as part of panel prep, from what I understand. Ok I'll go higher on the grit mayne 240-300? Then finish on 400 before I do the primer? when you say make sure the car is flat, I was unable to find a block guide coat online. Are you referring to those tubs (image attached) and you use that to see where the imperfections are?
Basically by the time you buy the manifold, turbo and waste gate then get all the fab work plus an lines for water and oil and add Labour it’ll come to 10-15
By BASHERnissan · Posted
Thanks for reply mate , yeah thought the vtec setup was out of place. I tried zero values like GTSboy suggested and it’s working fine for now. Would you now how to change it from VTEC to Nissan setup ? thanks for the help fellas
