I have already spoken to Hornet about this. I'm keen for a group buy if there's enough interest. I'm not in a rush so I was hoping GKTech would come out with their version sooner or later.
GkTech 'design' doesn't fit z32 & I'm not super thrilled with some of their feedback I've seen.
Member Boosted Zed is actually John, the owner of UAS & I know another member (fatz?) has run a group buy in the past
Where did you see feedback/info about the GKtech UCA's?
Nothing on the uca's obviously because they haven't built them, that said the design won't fit on a z32 in it's current form. Feedback relates to other suspension arms that 300 members have purchased & the overall quality they found. Then there's the fact that a lot of their parts labelled as fitting z32 don't actually fit on a z32...
I've purchased SPL arms for all my other adjustable arms & while they cost more the quality is fantastic, my only remaining issue is the fuca's which are currently just generic midori style arms. It doesn't look like SPL's will come to market anytime soon so I'll be going UAS when I get the chance.
GKTech are designing something.
In the meantime, Hardrace seem to be pretty decent. I have SRI (red ones) from JustJap, they've been working fine for a couple of years.
niZmO_Man to the rescue!! Came through with a set of Hardrace arms for me. Legend!
Thanks for all the input guys. I think I will still see what GKTech come out with, and/or go with UAS option in the long run, but these will certainly get me out of the tricky spot I am in.
Get some pics up of the broken arm.
Will do - I put the new ones in on Tuesday... took me longer than I thought it would, but all good now. The clunking/groaning/knocking sound I have become accustomed to has stopped which is good, and the front actually feels a bit tighter. I will take a pic of the old busted one when I get home.
A little hard to see in the picture, but the thread is stripped and the threaded part is actually cracked right through. The threaded section just slides in and out lol... so glad it finally let go on the driveway, and not on either the skidpan, or the freeway on the way home.
  • 2 months later...
How much castor were you running when that happened?
Garage88 eastern creek.picture says s thousand words about $450 off memory...attachicon.gifImageUploadedBySAU Community1429708384.269795.jpg
They look a lot like the ones i have, and are still going well after many years. My ones were from Notlec, who later went out of business. Other Noltec stuff was shit - radius rod bushes from them fell apart. Superpro replacement rod bushes are going well.
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
