Hi all,
I own an r34 gtt and am looking for an oil to use to suit daily driving and the odd track day. I live in Perth so it doesn't get that cold over here as well. If anyone could recommend what combination would be best ie 10w-50, 5w-40 etc it would be greatly appreciated !
Attached is some oils Supercheap sell. Any recommendations on what one to buy would also be great post-135000-0-56593000-1423492571_thumb.jpg
Thanks in advance
https://www.sau.com.au/forums/topic/453695-what-oil-viscosity-to-use/
Also before anyone says search the forums I've seen lots of stuff on what brand of oil people use but not too much on the viscosity, but if someone finds a forum discussing this my apologies and could you please link me !
If you go to the track at all a full synthetic gives you a measure of extra protection.
There are lots of opinions about viscosity but I use Motul 300V 15W 40
If you have an oil pressure gauge and preferably an oil temp gauge as well you can see what works for you.
  • Like 1
For years I've persisted with using 10W-40 weight oil as I believe that's what's recommend. Using that weight I've always experienced a slight amount of oil misting out through the front of the engine (cam shaft seals etc). Several seal changes over the years and different cam breather setups never fixed the issue.
I recently changed to 15W-50 weight fully synthetic and the leaks appear to be gone.
  • Like 1
Given the usage model of your car you could realistically use just about any of those oils.
Given that Perth gets pretty hot and that you plan to do some track work and that it IS a turbo, avoid anything with a 30 rating. You need at least 40. If you tend to run the oil to high temperatures (do you even know how hot your oil gets?) then a 50 would be better.
Out of all that lot in the Supercrap listing, I would lean towards the Penrite 10 10ths or HPR10.
  • Like 1
Been using Penrite Racing 10 for 8 oil changes so far and I can't fault it.
My car runs an external oil cooler, so the oil temp is at 80° for most of the time.
Highest I've seen it get to is 100° after some prolonged spirited driving, but it gets down to 80° pretty quickly and oil pressure is stable from when it first goes in to when I change it at 5000kms. Ive been tempted to go longer between changes but its not overly expensive
Have used Motul, Mobil 1 in the past and the car feels happier. Tempted to try the Nulon synthetic at some stage also
I reckon ?W-40 is the best choice. AFAIK the only two valid reasons to go thicker are;
1. To bring oil pressure up to spec in a worn motor
2. To hack around running your oil too hot.
Instead of #2, get an oil cooler that will keep your oil below 120 Deg, and use a full synth 40.
Yeah I know but I have <2 weeks to do all this stuff to my car for the track day and adding an oil cooler isn't an option right now, but when I get the time I definitely will. And thanks for the suggestions guys. I was looking at the penrite 10w-50 oil before and I think I'll go with it for now until I get an oil cooler, then maybe I'll go for a 10w-40 oil or stick with the penrite depending on how it goes. Once again much appreciation for all the continuous help here !
R32 GT-R, 160k+ km (probably more), no oil cooler, two overheats with 5W-60 (like 130+°C oil temps), three track days. Motor sounds the same as it's always been, car runs fine :).
Ran a track day with Racing 10 as well, I think it runs better with that, but my car runs hot on the track.
Now that I have an oil cooler, I might switch back to Racing 10.
Each to their own I guess but if its a street car that is only doing the occasional track day then frankly as long as its a reasonable quality semi synth oil can you really drive a car that hard on the road that a 10W-40 or 15W-50 or thereabouts is going to be an issue?
When you do a track day, the 1-2 times a year ALWAYS put a fresh filter and sump of oil in the car. That't my practice. And frankly people saying run a cooler, keep it under 100deg....my experience is your oil temp will run over 100, more like 110-120deg c which is perfectly fine.
Remember that the oil going through/around the cams and lifters is subject to far less shear and temp and only running at half the speed of the crank vsgoing through the mains and big end so you are only measuring the average oil temp on your gauge.
The old wives tail , which seems to hold true on race cars is run the oil over 100deg c so any moisture/condensation, blow by gases etc dont stay entrained. How true that is I dont know...but of course those engines are purpose built and toleranced accordingly
So that is the BS I tell myself and every time I go to the track I always run a genuine Nissan oil filter and Castrol 10W60. I love the viscosity, rape my engine with boost and revs and havent lost a bottom end.
If you find on your aftermarket pressure guage you have 60psi at 7,000rpm with the oil up to temp with XX oil then I would be bumping up viscosity so that you are between 70-80psi
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
