Leeroy - Yep yep, it's stock other than the tyres.
GTTR34 - Nahh - Using Harry's Laptimer on my iFail. I've got a DualAV XGPS160 10Hz GPS which I stuck on the dash to provide the data.
Nice one Matt, the lotus loves 3rd gear... Are
That's because 1st and 2nd gear are best for 0-100 times ;)
(And also because richo proves a long 3rd gear can be used for almost all of Winton)
How nice is it to have power!
That farken lotus is bullshit, no weight, awesome power delivery, stops and turns on a dime. It's super special cheater spec. Although as a passenger, you need to be really comfortable with the driver lol, it's somewhat um cosy.
Yep - it's a good little thing. I'm more and more pleased with the purchase after each track day...
I just wish I could do a track day every weekend :)
LOL @ being comfortable with the driver - yeah - you reach awfully close the passengers leg each time you're changing gears, and you're basically touching shoulders the whole time.
First time out in the CRX, pretty happy with a 1:49.32.
I was in group D and the traffic was difficult to deal with. Moved up to group C at the end of the day and it was much better.
Hopefully I can get out there more often.
Overall good day, would do a circuit club day again.
It was an awesome relaxed day! Although i didn't do much racing since i kept popping every imaginable silicon joiner off the cooler pipes it was still a great day! Keen for Broadford now !
I've got one of these and it works well :) Keeps up battery for the entire day, and it's lightweight enough to vecro it to the top of the windscreen without worrying about it flying off.
http://www.ebay.com.au/itm/Qstarz-BT-Q818XT-Bluetooth-GPS-Receiver-10Hz-Aus-Seller-/271742614711?pt=LH_DefaultDomain_15&hash=item3f451f3cb7
  • Like 1
Just be aware that it only works on Android.
Ask me how I know.
I need to get me one of them, the internal phone GPS is usually spot on time wise but sometimes gets "lost" and thinks I've cut across the infield which maps lap comparisons a bit hard some times
this explains a few things....thinks you got lost....yeah
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
