(sorry if this isn't the right spot to post this)
So I took my R34 into the shop and of course, the lovely coilpacks had pooped themselves. Now i'm not an extreme genius on cars, just really know the basics and what not. Apparently it's going to cost anywhere between $1200-$1500 to replace the coils (Which i think is fair enough due to them being pretty expensive by themselves), as they're replacing all 6 of them. The bloke called me up and told me he couldn't pinpoint which coil it was, due to the "layout of the engine" or something along those lines.
My biggest question is, am I being taken advantage of due to my age, and what sorts of prices have you been quoted to change out 6 coils + labour?
Sorry if this is an extremely basic question, however I just want to double check with you all!
(R34 25gt, by the way)
https://www.sau.com.au/forums/topic/453707-quote-for-replacement-coils-labour/
you are being taken advantage of. A good set of coils is like $500 and it takes literally two seconds to install them.
Well.
HOW FKN MUCH????!!!!
Take it somewhere else
SHIET.
Considering the establishment that diagnosed this problem, it would be worth reading up on how to change spark plugs and clean existing coil packs too.
You may find the coil packs aren't the problem, might be crook plugs, excessive plug gap, too much degreaser and so on.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
