Any tips on preventing turbo -> dump pipe studs or any other stud subjected to heat from snapping?
It seems no matter what I try I always have at least one stud either snapping or threading in it's bore.
•I always use genuine Nissan studs (inconel?)
•I always torque them to spec
•I generally chase the threads to make sure they're clean before installing hardware
•Tried using nickel anti-seize but it seems to gum up the threads making installation difficult
Any way to stop this, as I take my turbo off pretty often and it's annoying having to extract studs and helcoil each time.
https://www.sau.com.au/forums/topic/453759-prevent-exhaust-studs-from-snapping/
The amount of heat these bolts have to tolerate is huge,no way will they last forever its impossible, hot and cold,and then they crack and brake had to get mine replaced several times over the last 12 years.Do I still love my 93 skyline ? you bet I do bang for buck and if you look after them they are fantastic nothing better. :-) :-) :-) :-) :-) :-) :-) :-)
I would say the flange isn't straight, or the exhaust is causing it. Do you have a flex join in the front pipe?
Never heard of the dump studs/bolts snapping. Anti seize should be helping, but perhaps the nuts are crap too? They shouldn't be too tight or they will gall up and bind, especially if warm still.
Unfortunately the Skyline hangers are pretty crappy, there is nothing to stop the muffler moving side to side when you corner. This force is transferred down into the turbo/manifold, and the exhaust makes for a very long and heavy breaker bar. I always put a flex into the front pipe for this reason.
  • Like 1
Had this problem when I took my stock turbo out but I assume mine was just from old age as the bolts where the factory ones from 16 years ago. Do you have a link to where you are buying the nissan ones from as I need a set?
I was going to make a thread about this a while back. If you look up "landcruiser exhaust mount" you should find these rubber bushes with bolts attached like so:
http://www.ebay.com.au/itm/Landcruiser-HZJ80-HDJ80-Series-Exhaust-Mount-Rubber-Set-3-/201205416170?pt=LH_DefaultDomain_15&hash=item2ed8c700ea
I have replaced my rear exhaust hangers, and the cat converter brace with custom brackets and these rubber mounts. The rubber has flex in order to absorb vibration and allow for expansion of metal, but the exhaust cant sway in any direction very far. I find even hard hangers dont work because even if they dont stretch, the pendulum effect allows the exhaust to swing and touch things.
  • Like 1
Interesting stuff and perhaps a really stupid statement or question but I knew my studs were broken and a couple were but it didn't affect how the vehicle ran. I suppose my question is if I have a permanent street setup will I have to routinely remove these studs every year or two years?
Edited by Therealsandybang
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
