Its pretty common to have them fail, most people just replace the studs on the head whenever the mainifold or head is off.
Many heat cycles makes them brittle, however all of the previously mentioned issues such as warped manifolds etc add to the issue.
  • Like 1
I will add, besides the studs replace the yokes, washers and nuts too, I had quite a few of the stainless conical washers that were cracked in half.
Also I was talking stock engine, so once you start winding in some boost, manifold and turbine temps go up and the heat expansion will be greater, so they may only last 40 000k
Another thing, when studs break in the alloy head, the part of the stud which comes away, nearly always takes the last one or two threads with it, don't panic there are plenty left, you'll junk the head before you need to worry about helicoils.
You will also be tempted to over tighten the nuts which is a bad idea, as it will stop the exhaust manifold from sliding over the washers and yokes and put more stress on the studs. I use a open end / ring spanner (the ring end has offset) to tighten them, the open end will just fit the 1/2 inch drive of a Tension wrench, so set the torque you require and feel with you hands how much force is required through the spanner to reach the setting, then try and replicate that exact force when tightening up the manifold, you will be surprised how little force is required.
Edited by Missileman
  • Like 1
Nope not at all. Until you start hearing an exhaust leak you are in the clear.
I purchased my RB20 R32 and flogged the shit out of it for two years happily. When it came out for 25 conversion I found there was only 8 studs holding the exhaust manifold on, the rest were snapped :)
  • Like 1
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 馃挭馃徏 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 馃ゲ But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
    • That is correct,  I have a forged RB25/30det NEO hiding away safely and I wanted to use the very rare greddy vct adj cam gear on this new setup and so I just used the whole thing on my s1 instead of pulling it appear because I'm lazy af 馃槄馃馃徏
