Looking into buying an R34 GTR, had a seller take the car of interest to a reputable workshop of my choice this morning for an inspection.
Compression test results are as follows:
C1 - 145
C2 - 147
C3 - 152
C4 - 148
C5 - 148
C6 - 130
Leak down test results:
C1 - 6.5%
C2 - 6%
C3 - 5%
C4 - 7%
C5 - 9%
C6 - 15%
Now, the motor has been rebuilt and has forgies etc that were done mid 2013 (seller has provided receipts). It has apparently only done ~ 6000kms since rebuild... But obviously I have my concerns.
After speaking with the owner of the shop who did the inspection he ensures me it is a solid example and will give me no grief for daily use. (No track work as it doesn't interest me + I live in the sticks).
Told me it pulls very hard and after performing a leak down test he has narrowed the cause of lower compression in cylinder # 6 down to the rings.
I am sure some of you folks have been through a similar situation in the past so I guess my questions are:
- Should I walk away?
- Should I run away?
- Is the deviation between the first five cylinders to the sixth of serious concern?
Any info/advice/experience will be greatly appreciated and help me make the right decision as these cars are not cheap!
Cheers
Edited by shaunus
https://www.sau.com.au/forums/topic/453786-rb26-compression-test-results/
I had turfed the idea of buying that particular GTR the minute Fats said "walk away"hahaha.
You have to keep in mind that Fatz will probably lowball the guy, snatch the car out from under you and turn it into a track whore or wreck it for profit. Ulterior motives are ulterior! :P
  • Like 1
Walk away or budget to pull it apart, hone it and re-ring it. It wasn't run in properly.
This is in all probability what has happened. Yes it should get redone - but budget that and if the numbers stack up and the car is still good why not?
Link to car?
http://www.carsales.com.au/private/details/Nissan-Skyline-1999/SSE-AD-3066429/?Cr=4
To be honest mate, spending 50k on a car you'd want it to be near on perfect mechanically. I don't have the time nor patience to be bothered pulling the motor.
  • Like 1
a set of mild cams would drop the comp 30psi on a comp test, if that were the case those numbers would start to become decent..
In most other similar posts everyone is fine with a 10percent variance so why the walk away in this case?
Edited by AngryRB
A set of mild cams should affect all cylinders unless it's a scatter cam for a Mini. Besides, the leakdown results scale perfectly with compression results, indicating that it's all in the rings.
10% variance between cylinders is deemed acceptable for an original engine that's done a lot of miles. Not one that was supposedly recently put together carefully and only done 6000 kays since.
  • Like 1
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
