For Sale:
All located in South East Melb.
Y34 SuperMade Instant Gentleman Body Kit
imported from japan and used for the Viva Garage Group Buy. Includes Front bar, rear bar, sideskirts, foglight holder pieces, foglights, LED strip, SuperMade plastic bag + stickers.
reason for sale: kit was very thin fibreglass so i wasnt really happy with it. Viva have since added another layer to the front and rear bars. its a lot sturdier now, but I have changed my mind.
So far guys with the replica kits havent run into major issues fitting their kits.
Also, front bar has had a small bar removed to improve space for front mount intercooler.
Price: looking for around $1400 neg. will take price into consideration when negotiating postage.
I have access to body kit boxes so can be packaged neatly
KTF-1 Nissan CVT oil SOLD
For CVT Y34's and GT-8 V35's.
Price: $200 for one 4L can. unopened.
Extroid CVT sump gasket & O-ring SOLD
Price: $45
Y34 stock suspension
Front and rear. 106,000kms. car had major nissan service in 2014, not sure if they were touched though. comfy ride, no squeaks or leaks.
Front dust boots are rooted (as any Nissan with more than 500kms on it)
Price: $400
  • Like 1
https://www.sau.com.au/forums/topic/453809-y34-body-kit-extroid-cvt-suspension/
  • 1 month later...
4L unopened can of KTF-1 is available now.
also have about 2-3L of an opened can of KTF-1 that is pickup only.
Have a stock set of rear camber arms and rear traction rods for Y34 available too. $50 for all.
  • 3 weeks later...
added cvt O-ring, which is part of cvt.co.nz's "CVT service pack" but they want $75~ plus postage with the sump gasket.
Unopened KTF-1 oil is now sold.
  • 2 months later...
  • 1 month later...
Have front and rear factory Y34 bumpers in KH3 black. Excellent condition, front bumper has small hole cut in it for a parking light installed in Japan.
Can post pics on request. $200 per bumper
  • 3 months later...
  • 8 months later...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
