found fuses all ok . also check eng light has come on have tried reset but light stays solid no flashs hep to reset it screen still not working so not to worry will look at other ways to fix at a later time.
So does this car have a warranty or was it a private seller?
I'd be pretty worried if that was my car I just payed for with random issues.
Edited by Ben C34
Check if I had a brake signal mod done to it could explain the cel. Is it running rough in anyway. Check your air bag plugs under the car seat are plugged in properly for the srs light to
Who would of thought that. If your still having problems with screen it could be the ribbon in the back of it thats broken from going up and down.
You will have to remove dash to get to it. Check there is power at the plug going into the back of tv first. Then there is a flexible ribbon out of that which goes in the back of the screen.
Do any of the buttons beep when you press them? Sometimes the TV can be left in the VTR/AUX which will leave the screen black if nothing is plugged into it.
It might only be there if the tv button was pressed. Do your buttons beep when you press them. If you press the buttons and nothing happens then its not getting power. What happens if you press the eject button on dvd rom?
You will help me work it out if you answer those questions
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
