Hi SAU, I need your help. This is a long going issue with my R34GTT that I havent bothered fixing yet, I fitted Bilstein coilovers from another R34 and got new bumpstops n grooves cut in by Sydneykid sometime ago, the pics are old btw.
Issue is all the clanking (esp from the rear strut tops) when hitting mild bumps and imperfections at even 30-40km/h. The fronts also do this, on top of that they creak real loud like a mofo when turning/braking esp on drives, humps etc. At normal speeds you cannot really hear the creaks when turning.
I need to identify which part from my first pic I need to replace, from what I know its the strut mounts or tops but my ones not a single item, rather a series of washers n rubbers>>first pic. So what do I replace and from where, any alternatives or has to be Bilstein? Thanks
Well.....only the washers and nuts are Bilstein. Everything else is Skyline.
OK, OK, the bump stops are not OEM, but hell, as if they matter.
They're not really strut tops at either end of the car either, because all they really are is upper spring retainers. There's no bearings in there to make noise. if there's creaking and shit going on, then it's probably in the dampers themselves (or possibly in any one of the other bushes/bearings in the rest of the suspension) and perhaps you should just take it to Gary and get him to have a look.
The noise only started with my Bilsteins- it wasnt there at all with my Cusco coilovers and its definitely coming from the top of the struts both front n rear ( front creaks during turning), so what else could it be- as u said it dorsnt look like these struts have bearings..my suspect is those thick black rubber/plastic washers but please enlighten me
Well, at no time does any part of the damper need to rotate around its axis - there are not "struts"....therefore, any creaking from turning the wheels is either coincidental, or maybe just maybe because the top nuts are loose or something. Otherwise, it's as I said in 1st reply.
The springs are not fully captive if they're banging and clunking, possibly from deteriorated rubber or that the springs are too short for the shock. Creaking from the top hats could be that the rubber has deteriorated and causing the spring edge to rub in its mounting position because it's not completely captive.
Does the spring move at all if you try and jerk it in its mount? Try it on a bench vise.
Sorry guys been pretty busy with stuff, the 'loose spring' is what it probably is because it is not that sprung when captive in the car, I am pretty sure I could turn it on its mounts with a little bit of effort while its still on the car. Will report back later
And loose possibly because I moved it down on Sydneykids standard cut grooves to give the height I want.
I always wondered how people went with the grooves. You could try getting some spacers and placing them inbetween the top hat and lock nut to force the spring captive. But I hold no responsibility if anything happens, as it's just the first idea off the top of my head.
The problem with all this is you are running out of shock travel - note shock travel not spring travel. I don't care how good the shock absorber is if you don't have any stroke for it to work in it wont work.
See here.
http://www.sau.com.au/forums/topic/374385-bilstein-coilover-conversion/page-1
Part of the fix is to replace the strut tops which gets you shock travel back. As an aside replacing all that old stuff will also get rid of your squeeeeeking & clunking.
  • Like 1
Wont the use of spring spacers simply be the same as moving my springs UP on the cut groves- will give more height n shock travel like spacers will. We pinpointed the creaking to the front left strut (not sure if its from the strut tower top or bottom joint) when turning during the LAST 20-30% of full lock and when the car is leaning sideways on that shock during turning. During the last turns close to lock is when the creaks happen even when parked but moreso at low driveway speed.
The rear strut clanking n rattling tops during small bumps is a separate story
My R34 GTT has similar symptoms, I had bilsteins fitted and re-used the stock springs at near-stock heights (dropped the rear a little bit via the circlip grooves on the shock to make it sit level.. the front stayed the same). Occasionally clunks a bit when at slow speeds and turning, eg into/out of driveways. I haven't managed to narrow down what's causing it yet.
I seem to have this issue as well. Clanking and clunking when going over speed humps or moderate road imperfections. I'm running Bilstein B6 Dampers and King Springs.
Rather than a dull thud, the car makes more of a 'crashing' sound for lack of a better term, when going over bumps.
Check how much "droop" you have. By droop I mean measure the centre-of-wheel-to-arch when the car is on the ground and then jack the car up so the wheels are hanging in the air and measure it again. You need at least a few inches of droop or your shocks will 'top out' out on the exit of a bump. Basically, your car goes over the bump, wheels go up, which pushes the car body up a bit. On the exit of the bump the body is higher, wheels extend and BANG the shocks reach the end of their travel, there is no bump stop in this direction and it sounds really ugly (and will destroy the shock).
The workshop who installed my Bilsteins (who SHOULD KNOW BETTER given their proximity to the Bilstein importer) did not remove the spacer inside the shock that limits droop when used with lowered springs. They gave me a car back that had zero droop at the back. If I hadn't seen it with my own eyes I wouldn't have believed it.
Just and update, I remove a front dust boot and reinstalled the strut into the car. On level ground there is about 1cm of travel between the (shortened) bump stop and the shock body. That is with King Spring lows and a 1cm lower slot in the spring perch. So I guess I have been bottoming out on everything larger than a pebble lol. Time for some base-height adjustable coil overs.
No. Time for some new strut tops to allow the reinstatement of shock travel.
These ones.
http://www.isccoilovers.com.au/coilover-spare-parts
Get the ones with the rubber bushes front and rear but you have to ask them for the front ones as they aren't listed.
But read this first to understand you need a couple of other bits to make them fit your Bilsteins - plus they work with 65mm springs not the Kings. If you want to retain the King springs you may need something different. Not sure what that would be.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
