Hi Guys,
I want to install a LC1 wideband into my R32 GTST, and was after some advice on the best way to do it. Should I install it in the NB factory location and wire up the factory plug for the power, NB emulation, ground ? Also where is the best location to route the cable into the cabin. Any advice would be appreciated
Thanks
https://www.sau.com.au/forums/topic/453873-wideband-install-advice/
What do the instructions that came with the kit say? My AEM kit gave specific instructions for where to mount it, something like at least 1m away from the turbine outlet and at least a 10 degree above the vertical.
I think it does work in the stock location, but it isn't the best spot to put it. I can see how it might be an issue, with the extra heat that would be right at the exit. AFR's will be the same the length of the exhaust pipe, its the delay in having the sensor at the back compared to at the front, obviously it does take a little bit of time for the exhaust gas to get to the end of the exhaust pipe
I would look at the instructions and see what it says. If you mount it in a different location then you can run it through the gearshifter hole, this is where I ran mine (its mounted about half a metre pre-cat from memory)
It would really be helpful to see some sort of wiring diagram that innovate give with the sensor. I could look it up and see, but I can't really be bothered right now. I'm hoping you have at least had a look at what it says before making this thread.......?
I looked at the manual just now. Read that, the answer to all your questions are there amazingly......
Turbocharged Vehicles:
Install the bung downstream from the turbo before the catalytic converter. The high exhaust pressure before the turbo interferes with the lambda measurement and the high exhaust temperatures encountered there can damage the sensor.
The factory NB is in the down pipe that is coming off the turbo, I could get a bung put in I suppose and run it up through the gearshifter hole and power it via cigarette lighter? What 12V source and ground did you tap into?
Just thought I could replace the NB and use the LC1 NB emulation , but thats imperative
I installed one on my stagea just before the cat, then ran the cable up through a hole in the transmission tunnel (drilled a hole).
The "proper" way to power it is to wire a relay to the battery, then activate the relay via a 12v source when the key is in the on position. This ensures you know how much current is flowing through a circuit, whereas if you draw 3 amps through an existing circuit, that may blow the fuse, create a voltage drop etc
For me, the cigarette lighter turns on with accessories, so not desirable. Test yours with a multimeter to be sure.
A workshop manual will have wiring diagrams which you can use to find an "ON" position 12v source.
Always mount it away from the turbo outlet, as prolong heat exposure will kill the sensor. Just get an exhaust shop to weld the bung before the cat but after the turbo.
I ran my cabling up through the stock EGT probe for the dashlight.
I just used the ignition source under the steering column for all wideband installs I do. Works a treat, just use a clean ground, preferably on the cars body instead of a shared ground.
Thanks mate , is it run from one of the fuses? Or another location? First time I have installed one. Wouldn't have a pic? :P
straight off the thick cable off the ignition barrel into a 5 amp fuse :)
I might have a photo at home.
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
