Located Gold Coast will freight all parts auswide
Gearboxes r32 push type $500
R32 pull type late model $750
R33 pull type $800
R33 converted to r32 manual speedo drive and push bell housing $850
N1 headlights with grill brackets $500
-5 twin turbos $1600 only 1200km use absolutely perfect cond.
Dash pad $160 perfect demister vents no ac vents (passenger and middle vent available for $120pair) or $260 the lot whole dash VGC
Gtr fuel tank plastic with walbro pump and sender $200
Cluster surround and working clock $180
Drivers door switch $70
Centre gauges $70
Steering surround $20
Telescopic part $20
Twin turbo pipe in black both pipes and hose $100
Abs $150
Latch and support with horns $70
Stainless dumps brand new $100
Mines stainless dumps and front pipe $600 3" bell mouth type
Rear seat good cond. $100
Rear subframe $100 bare
Spare wheel $50 genuine jdm r32 gtr
Rear door cards $100 pair
785cc injectors billet rail Turbosmart reg with -6 braided line $500
Textured stereo surround $80, ashtray $40, manual surround $40 boot $10 or $180 the lot
Drivers window relay $50
Heater vent actuators $50ea both available
Gtr r32 brakes and cross drilled rotors $200
Plenty more parts available preferably text or call to discuss 0414596256 more photos available also
post-44496-14240410126628_thumb.jpgpost-44496-14240410293949_thumb.jpgpost-44496-14240410570334_thumb.jpgpost-44496-14240410737196_thumb.jpgpost-44496-14240411098878_thumb.jpgpost-44496-14240411281251_thumb.jpgpost-44496-14240411425313_thumb.jpgpost-44496-14240411664365_thumb.jpgpost-44496-14240411922718_thumb.jpg
https://www.sau.com.au/forums/topic/453896-for-sale-r32-gtr-wrecking/
  • Replies 40
Is the textured stereo surround in good condition with no cracks or scratches and all clips?
Can you send a pic?
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
