Well I've been training weights for about the last three years with reasonable progressions in some areas and pretty poor progression in others...
Have spent the last couple of weeks reading through Markos' thread 'Powerlifting'......much of the time in awe ha-ha.
To date I've just been training at home and only had a proper squat/power rack that I built for the last 12 months or so along with one strongman session per week (yoke, farmers walks, log etc.......).
My best mate is a PT and has just secured himself a warehouse where it will be focussed around 'Powerlifting', 'Weightlifting' & 'Strongman'.
In return for me fabricating some of the equipment I will be able to train there for free which I believe/hope will certainly help me progress especially for those times where I perhaps haven't gone for that extra rep, set, weight etc. (we all do it even if only subconsciously) and just having other lifters around can only be a good thing......
My current stats are as follows: 30yrs of age, 175cm @ 82ish kg
Current 1RM deadlift = 200kg
Current 1RM squat = 150kg
Current 1RM bench = 80kg (this is clearly the one that needs a lot of work)
I always figured I just had a weak upper body, in comparison to my lower body anyway......but after delving a little deeper I have visited a Chiro (Does Strongman himself) and had X-Rays taken, I will try attach the X-ray's.
Basically it turns out that I was born with a short leg (8mm shorter on my right than my left), apparently this is fairly common I am led to believe, so now all my right shoes have an 8mm heel.
What this has caused is pretty evident in the picture attached and that combined with a poor posture has made my shoulders very weak and therefore overhead press, bench etc. hasn't progressed as it should or I would have hoped. I am currently seeing the Chiro twice a week and doing rehab everyday hoping to get things sorted as quickly as possible but these things take time.
My goals I am hoping to achieve by the end of 2015 are as follows:
Weight = 85kg max.
1RM deadlift = 230kg
1RM squat = 175kg
1RM bench = 100kg
Total = 500kg minimum.
What are peoples opinions on those goals? too ambitious? too easy?
Love to hear peoples thoughts/opinions.......
Edited by mr_rbman
  • Like 1
https://www.sau.com.au/forums/topic/453946-2015-goals/
But meh to goals...goals limit potential
Just aim to get stronger and stronger all the time and put in 100%
You may not reach goals if you don't have any, but you'll know you're as strong as you could have been
https://www.sau.com.au/forums/topic/453946-2015-goals/#findComment-7481838
Leesh, planning on using a programme that focusses around the three lifts.
Squats one day a week with supporting exercises.
Bench one day a week with supporting exercises.
Deadlift one day a week with supporting exercises.
Strongman session one day a week.
  • Like 1
https://www.sau.com.au/forums/topic/453946-2015-goals/#findComment-7482185
Bench wise , bugger it off the program for a while and focus on shoulder girdle strength and thorasic mobility. Happens to lots of people doing the usual gym-bro training. Short legs , long legs or no legs its not posture.
You have weak external rotation and imbalance with the stronger internal rotation muscles. So not stable enough in the lift when you press. Makes you weak.
Likely if you have a degenerative injury to your rotator cuff, pretty common. You will almost never feel pain there as it gets refered(front of shoulder even wrists) Also, injury will degeneratively progresses without pain till you bugger it right up. To see if you have a problem, stand against a wall and rest a tennis ball between the wall and your back(shoulder blades). Lean against the ball , roll it around the should blades and see if you have any tender spots. If you do then you can roll the trigger points, probably want to stop anything that involves internal rotation for a while. There are conditioning movements you can do.
Train the shoulders up and bench will be no drama to progress.
https://www.sau.com.au/forums/topic/453946-2015-goals/#findComment-7482737
  • 1 month later...
23/3/15
Deadlift
6x8 @ 70kg
5x8 @ 80kg
4x8 @ 90kg
3x8 @ 100kg
3x10 @ 110kg
farmers walks
x20, 20m walks 50kg a hand with 30 sec rest
5m rope climb
6 with 30 sec rest
tyre flip ~200kg
3x10
Edited by mr_rbman
https://www.sau.com.au/forums/topic/453946-2015-goals/#findComment-7503930
squat
6x8 @ 50kg
5x8 @ 60kg
4x8 @ 70kg
3x8 @ 80kg
3x10 @90kg
overhead press (from behind head working on opening up the shoulders/rib cage...
1x20 @15kg
1x15 @ 20kg
1x12 @ 22.5kg
1x10 @ 25kg
1x8 @ 27.5kg
1x6 @ 30kg
1x4 @ 32.5kg
1x2 @ 35kg
1x2 @ 37.5kg
1x2 @ 40kg
chinups
3x10 @ bodyweight
https://www.sau.com.au/forums/topic/453946-2015-goals/#findComment-7503934
Front Squat
5 @ 70kg
3 @ 90kg
2 @ 110kg
1 @ 115kg
1 @ 120kg (PB)
yoke
x12, 20m walk @ 90kg
x5, 20m walk @ 140kg
x4, 20m walk @ 170kg
x3, 20m walk @ 190kg
x2, 20m walk @ 210kg
x1, 20m walk @ 230kg
farmers walks
x6, 20m walk @ 45kg a hand
x4, 20m walk @ 65kg a hand
x2, 20m walk @ 85kg a hand
overhead press (from behind head) wide grip
1x20 @ 15kg
1x15 @ 20kg
1x10 @ 30kg
1x8 @ 35kg
1x6 @ 37.5kg
1x4 @ 40kg
https://www.sau.com.au/forums/topic/453946-2015-goals/#findComment-7507100
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
