Hi Guys
I recently had Garrett -5 turbos install to my R34 Gtr, it now has alot of lag which make street driving a bit "slow". My car before with the stock turbo had a very flat curve, full boost at 3500 rpm, max power 244awkw, very responsive with hardly any lag, but turbo looses puff after 7000 rpm.
So I decided to get bigger turbos to fix the top end, was expecting some lag but now the car hits full boost at 5000 rpm! It takes at least second or two for the turbo to hit full boost. New turbos now make 292awkw limited by stock injectors and pump etc (will be done at a later stage). Now before you guys say I should have got the -7 or -9 turbos, my goal eventually is to get above 350kw on 98 or 400kw on e85.
So my question is can someone tell me how to lower the lag down to 4500 rpm or even 4000 rpm if possible. Tuner says intake hard piping, bigger inter-cooler, exhaust shops says twin 3 inch into 4 inch exhaust, internet says cams, don't know what to do. Just want to lower the lag before I chase for more top end power, any advise or help from you guys would be much appreciated.
My set up is
Standard: motor, inter-cooler, injectors, dumps, cams, pumps etc
Mods:
Apexi pods
dual 2.5 inch to 3 inch nismo exhaust
Tomei cam gears
Splitfire coil packs
Greddy ebc
Haltech platinum pro ecu
Alloy radiator
You need to upgrade
inter-cooler,
injectors,
dumps,
pumps
and at least a 3.5 inch exhaust from front pipe collector into good hi flowing system
especially for e85
you have too much restriction currently for good response out of -5s
at 3500rpm you should be close to 50-70% of full boost
Also check your cams are dialed in for response.
Its a shame you didnt do the dumps with the turbo change. If you dont want to spend the coin just do the 3.5 inch exhaust from front pipe collector into good hi flowing system..... you should get improved response just from this.
Edited by XGTRX
Thanks xgtrx, i will be doing all the supporting mods later, just saving up for the build. Was told cam gears was dialed in a bit. So you think for now just changing the exhaust will improve response in the lower rpm? My nismo exhaust is from turbo back with twin cats, i'll have to change the entire exhaust system, would twin 3 inch into 3.5 inch be enough for the future as well? Thanks for your input on this.
-5s are very laggy turbos for RB26. and in lot of cases, the standard "T1.5" turbine manifold gets bored out, which adds more lag. if you are using adjustable cam gears, dial +5 on the inlet and leave 0 on exhaust. That will advance response by roughly 300RPM. Or get HKS V cams with active VCT cam set, that knocks out about 700RPM of lag.
Alternatively get -9s or check out our latest single development on our thread.
  • Like 1
No worries mate. Yeah the 3.5inch exhaust will make a noticeable difference just get the exhaust place to cut out the 3 inch restriction near the down pipe flange and put a 3.5 inch flange. Also don't worry what people say, -5s are perfect for the rb26, they come on nicely from 3500ish.
IMO the Dash 9s are purpose built to do a good job on a fairly std GTR . I don't think anything is going to boost like standard R34 turbos and pull well over 7000 revs . 2568ccs isn't a whole lot for 1500 kilos of GTR and the roads to big power is breathing better at higher revs . The cost is boost lag because bigger is generally heavier and needs greater gas speed to overcome the inertia .
Everyones idea of adequate performance is different , usable performance probably doesn't involve 7000 plus revs in a street car . The killer of adequate imo is numbers because everyone seems to think if you haven't got 400 at the bags you haven't got a life . V8ers with longer arms than legs think like this . Voy oight .
A .
Beauty is in the eye of the beholder.
I find -9s boring, but that's just me. -5s are very good in-between turbo, yes, a bit more lag, and come on nice and strong. I have driven Laggy -5 set ups and more responsive -5 setups like mine and you can improve the response significantly with the correct breathing support to optimise the turbine spool. But anyway it's what ever floats people's boat. When my turbos have had enough I will be going TO4Z or similar because that's what I like. Obviously the op has made his decision with turbo choice and ask a specific question, and the answer to his question is YES, based on his current setup he can improve response by 500 rpm or more with certain changes without emptying his bank account, it would have been nice if he installed bigger dumps when he installed the turbos though. My 2 cents take it as you will.
Get it on the dyno, get it tuned, advance the cams for earlier response.
Also make sure the wategates are shutting properly.
Dyno tuner should be able to pull much more bottom end into it if the wategates are OK.
Ive seen GTR's change dramatically in the way they drive from tuner to tuner, some tunes have more lag but plenty of top end, some come on hard but start running out of puff up top, some are a good balance.
  • Like 1
Ok I am also speaking from my experience.
Things you do not need to waste money on.
Intercooler - I run 400kw with standard R32 intercooler although i have a hard pipe kit.
Things that are needed to make it more responsive.
1) Dump pipes - your tuner should have recommended when doing the turbos.
2) Exhaust - I run 3.5inch (as i said 400kw)
3) Decent tune
4) set of cams to bring those turbos alive 500rpm earlier. I use Tomei Type B poncams but there are others.
5) Lighter forged internals. Brought my turbos on 300ish rpm quicker.
You should see a good increase in response.
Do not forget a decent oil pump if you do a build with all the supporting mods (as you say).
Oh E85 for 400kw.......your tuner is not very good haha.
I run that on 98 and that is with 600cc injectors. If I had 700cc's it would be 430 odd.
Edited by Stixbnr32
If you are chasing response then leave std intercooler, leave std injectors, std fuel pumps etc. They are all fine if youa re just looking for a more responsive 300-310rwkws
As others have said spend the time on the good quality dump pipes that have 76mm outlet. Get matching front pipes and then get a good 3.5" exhaust that matches the merge of the 76mm front pipe.
From there check cams are set as per others comments...check the Apexi pods dont need a clean and away you go. Then just make sure your tuner knows what he is doing and isnt sitting on the fence with regards to ignition etc
My 2c..if he is telling you that you need a bigger intercooler, hard piping kit etc to cure the lag then either there is more to the story or is trying to milk money from the situation.
If you are trying to improve respnse and up the power to 400rwkws that the turbos are easily capable of then the story changes
  • Like 1
Roy is spot on with what he said right here: quote 'As others have said spend the time on the good quality dump pipes that have 76mm outlet. Get matching front pipes and then get a good 3.5" exhaust that matches the merge of the 76mm front pipe.' get rid of the 3inch collector collar and flange and full 3.5 inch exhaust. Like this
As everyone here has said for response exhaust does 75% of the job, cam timing does at lot as well. There are other ways of increasing response but most require a lot of commitment and money.
Leave the standard cams in there as longer duration camshafts will actually be detrimental to response
I agree, a shorter duration camshaft comes on quicker so leave the stock one in there.
Pretty much sort out any exhaust side restrictions, play with cam gear timing and if the car is mechanically OK its down to the tune only.
Thanks every one for the advise so far, looks like dumps and exhaust will be my first to do list.
Reason for selecting the -5 turbos is that the car is a weekend car and i plan taking it to the track. Will be going to wakefield in a few weeks time
As the car is not driven on the streets all time so didn't mind a bit of lag as long as theres mid range and top end. Happy to put up with some lag just not 5000 rpm which i think is too laggy even for a track car.
Car was tuned by Adam from JEM and he said that he tune it with a balance between top end power and response, if he reduced lag would also lose top end. I will attach a dyno sheet when i get home tonight so you guys can have a look for me.
considering you've maxed out the injectors and must still be at low boost I'd say it would be a better idea to tune for best response as you can just push boost until you run out of injector flow...
3) Decent tune
hey stix
im doing identical setup except im keeping stock cooler pipes for the "its bog stock" look. did you need to change to hard pipe or just wanted to for obvious reasons.
what boost did you use for that power on 98
i think most have covered it
intercooler wont change lag profile
1) displacement will change lag profile (stroker kit)
2) vvt kit will change lag profile (VCT or HKS kit)
3) tune tune tune (more timing in boost build)
4) cams, cam gear adjustment
5) explore exhaust manifold setup / split pulse etc - anything to get the turbocharger exhaust wheel moving quicker
6) downgrade the turbochargers to smaller exhaust wheel or different turbocharger profile
obviously they range form cheap, to outright mega expensive
  • Like 1
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
