You lol, 10 million different opinions on how to do it
Comes down to how much you wanna spend, setting up a high powered GTR for track duties is an expensive exercise if you want to do it with some sort of reliability.
If I were you,
Keep 2.6, Sort out the exhaust, standard Intercooler, standard cams, fuel pump with wiring upgrade, ID 1000/2000 injectors AND put -9s in it with cams gears dialed for response
That's for street duties and will net you 350ish rwkw.. Sh1t starts to break and get expensive from here on in
For track your gonna want a sump baffle, decent oil pump (oil restrictor depending on pump flow), oil cooler, catch can... If your going that far shit put a stroker in it with a new valve train.. See how it doesn't end?
Haven't even started on brakes and suspension when it comes to track.
BTW -10s are a no no on a 2.6
If I were you,
im not confused im giving advice here not asking for it lol
was just saying in response to being told to that i should stroke out my engine that if i ever did that i would consider-10s on the 2.8ltr
piggaz had a 2.8'with gtrs (-10s) drove like shit they are the worst turbo ever made, 2.8 with 5s is where it's at
  • Like 1
yeah -5 specs are really one of the best turbos out there imo. the mismatched dimensions of the 2871 only suit drag, peak power at any cost applications.
Hi guys got a quote back for the exhaust, twin 3 inch into 3.5 into 4 inch in stainless steel supply and installed with black finish $2000, $3000 for the bronze finish, does that sound right?
Why does it step from 3.5 to 4? Why not go 4 inch from the merge?
What's a bronze finish?
fark..... get another quote from somewhere else... unless you want to show the under your car you can get mild steel with a stainless rear muffler for the $1200 mark. shop around mate
shit no, 3.5 is obviously all hes got in stock. tell them 4" merge and you'll do it for 1300 can only ask
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
