as a comparison;
prev setup 3850rpm 135kw
current setup 3850rpm 80kw
racepace comparison 3850rpm 180kw
but you can't compare std displacement vs "built motor" it could have anything in there
but there is merit in picking the right turbocharger combination as shown on the dyno plots
  • Like 1
Now before you guys say I should have got the -7 or -9 turbos, my goal eventually is to get above 350kw on 98 or 400kw on e85.
So my question is can someone tell me how to lower the lag down to 4500 rpm or even 4000 rpm if possible. Tuner says intake hard piping, bigger inter-cooler, exhaust shops says twin 3 inch into 4 inch exhaust, internet says cams, don't know what to do. Just want to lower the lag before I chase for more top end power, any advise or help from you guys would be much appreciated.
My set up is
Standard: motor, inter-cooler, injectors, dumps, cams, pumps etc
- Good for 300+ kW's at the rear wheels.
- 350kW's to 400kW's you will need to upgrade Injectors / Dumps / Pumps / Re-Dial Cams. Stock Intercooler should be fine until the 400kW mark.
- Also depends on the health of your engine if it can handle the 350-400kW mark.
Mods:
Apexi pods - Good, well stock Air Box can handle 300kW's at the rears (R32 GTR) and from memory the R33 and R34 GTR can handle 350kW's at the rears if not more.
dual 2.5 inch to 3 inch nismo exhaust - Go a full 3.5" for 350kW's at the rears and 4" for 400kW's at the rears.
Tomei cam gears - Good!
Splitfire coil packs - Good!
Greddy ebc - Good or does the job
Haltech platinum pro ecu - Good!
Alloy radiator - Good!
-5s are very laggy turbos for RB26. and in lot of cases, the standard "T1.5" turbine manifold gets bored out, which adds more lag. if you are using adjustable cam gears, dial +5 on the inlet and leave 0 on exhaust. That will advance response by roughly 300RPM. Or get HKS V cams with active VCT cam set, that knocks out about 700RPM of lag.
Alternatively get -9s or check out our latest single development on our thread.
^^ This.
You can Re-dial Cams / Crank Angle Sensor / e85 and a Re-Tune but the is not much more unless you go HKS V-Cam on a 2.6lt or go 2.8lt. or 2.8 V-Cam / Rebuild.
^^ This.
Cheers for the comments, yeah looking for a 4 inch exhaust now to future proof.
  • Like 1
Interesting views about -5s being lag monsters.... I never really notice because I am always in the right gear and never go WOT when I am at 2500 rpm. Depends on the style of driving. I keep mine at 3500+ when I drive daily. Suppose it's my style of driving that makes my -5 setup very responsive. As mentioned previous if I am on part throttle at about 3500rpm and give it a boot, I feel minimal lag as it's at least 50% boost and ramps up so quickly I don't even notice it. If you expect -5s to come on hard at less than 3000rpm, well they won't, so to match your driving style you need smaller turbos. If you drive similar to me then -5s definitely are not laggy.
  • Like 1
Lol. It only "feels" more responsive because you are always high in the rpm.
Op should've taken the time and read the 30 40 pages on comparing -7 -9 -5 turbos.
So what's ur point?
My point is that I have no lag problems because it suits my driving style OR I have adapted my driving style to suit the car. Either/or it doesn't matter. Perfect set up in my eyes.
Ive been quitely haveing a chuckle at this thread, and this is the first real post thats nailed it.
If you want linear power with no lag, some people should realize they need to fit smaller turbos and get rid of the high power dreams or just go and buy a NA.
How would most here survive driving a S2000, the cars dont produce anything under 6500, yet they are blindingly quick when driven as they are designed to be.
If you think -5 are too big and you want more power, shift down a gear to get them into their RPM range or fit small turbos, it shouldnt take pages to relize its in the driving style or turbo choice.
  • Like 2
Hmmm. And I can change my driving style to suit a car that has a t88 on it as well
Yes but you may find its a little too much power on tap.
-5 wont present this, unless your in the wet on Kmart china special tyres and have absolutely no driving ability and throttle control in your right foot.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
