I'm sure a mate would do it for a slab of beer. Some bloke does them on here for $100 exchange.
It most Definately does make a difference. Plenty of info on the net about it.
While we are on the topic of exhausts. I've got hks gt-ss (-9's) turbos going in atm with hks dumps.
before you go any further get rid of the HKS dump pipes and go to an open belmouth design, due to the design of the hks pipes they are a pretty major retraction
Yeah I have read the topics relating to the mod, makes sense why it works so well. Anyone in Melbourne?
It was a very stupid design from Nissan. A little bit more thought would have gone a long way, but I Spose it worked well for it's intended purpose of 300 hp - give or take.
If you want response and internal gate then maybe a EFR8374 might be the "right" answer?!?
I know that my 6262 is better down low and up top that -5s so the EFR8374 should be even better with response and also be able to make more power than the low mounts.
For reference here is a 6262 vs -5s with similar specs on same dyno (6262 running more boost)
received_10153635513684616_zpsybzyo0oc.j
I see that the new turbo tech is good but some people have a budget want around the 400kw mark and do not want to change front pip manifold, dump pipe, intercooler pipes, Intercooler and BOV.
You still can get good results and more than enough power and response with -5's without having to change to a single turbo.
that is what i honestly think and achieved with my build.
Edited by Stixbnr32
See this makes me sick in the pit of my stomach :) I love my singles, but the other day I was even pulled over in my daily BMW so the plan for the R32 is get it engineered with an RB26 and low mount twins. :( All so I can continue to enjoy it as a fun club-street car for years to come...and be slower. :(
Well, from Matty James-Wallace' back to back between the -5's and the internal gate 8374 it's night and day. Comes on 5-700 rpm earlier than the -5's. I'd believe it too after having the pleasure of experiencing a GTR with an EFR on it too.
Yeah I've been in Matt's car and it's impressive. Hard to judge being a 3.0L vs my 2.6L, actually next time I'm at the dyno I'll try and grab and overlay.
My expectation is a EFR8474 would be a few hundred rpm earlier than mine any only miss out on a little bit top end on same capacity motor.
Edited by SimonR32
My expectation is a EFR834 would be a few hundred rpm earlier than mine any only miss out on a little bit top end on same capacity motor.
That would be good for an overlay.
Interesting you say that about the top end. The 8374 has 62.6 mm inducer and 83 mm exducer compared to the 6262 of 62 mm in and 82 ex. I realize its a bit more complicated than that but food for thought as thr EFR is has a bigger front fan on both accounts.
The right sized single could certainly come on earlier than twins because you have 6cyls driving one medium exhaust exhaust wheel. On twins you effectively cut the engine in half to drive two smallish to medium exhaust wheels, this is what drives the lag profile.
Also before you go and buy random parts talk to a workshop in person and give them the problem statement. This might save you a few $k in parts only to find it does nothing to shift the boost profile where you expect it, ie I think you expect a 600rpm+ shift in boost profile from those parts, I'm not convinced they would get anywhere near that amount of change in response.
Would be curious as to where GTX2860/63s (modified for OEM fitment) fit in the mix.
They should be an improvement over normal -5s, but enough to give the EFR8374 a run for it's money? Maybe not.
Issue is, who i going to do the back to back. Its alot of coin tied up in all those parts :(.
If only a company makes some steam pipe manifolds... everyone makes that stainless balla manifolds that only a few can afford...
If like to see either EFR6758s or PTE5130s as a true bolton for the RB26 so the small twins can enjoy some of the tech the big singles have been getting :(
Manifolds are a drop in the ocean really.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
