R34 Gtr Garrett -5 Turbo Lag, Need Advise
baicai
If you don't mind high mount for the EFRs then just buy their twin kit :thumbsup:
Me, I'd prefer the stock manifolds and to have the turbs in the factory location :)
Can even use your factory style front pipes with the EFR kit. The full race dumps bolt upto it.
But looks like a disaster under the bonnet
Hi guys, so picked up the HPI dump pipes today. Spoke to the seller and he said the dump pipes should connect to my existing nismo weldina dual 2.5 inch exhaust as the flanges are the same size. I thought the HPI dumps are 3 inch and won't work with my existing exhaust. To cut the story short, I won't have the budget to get the new dual 3 inch exhaust until later this year, my questions is will the dump fit onto the nismo exhaust and is it worth doing it now or wait for the new exhaust and install it all together?
If your stock dump pipes fit then something tells me that the hpi ones will aswell
I think he means there is going to be a lip going from the 3 inch internal diameter dumps to the 2.5 inch front pipes.
Just do it all at once. Bugger doing stuff multiple times.
Personally I don't find the standard system that hard to work on, there are a number of people here who have seen me get the turbos off in 2 hours
can i pay you 2 hours labor next time i need mine swapped?
lol, well it still a bargain even if its a half job??
id then have the option to purchase the re install or
i could now afford to tow it and finish it off myself having saved a fortune and not slicing the f@#k out of my baseball mit hands that fit nowhere.
so for the record im still keen
yep sure thing! one question tho, how do you intend to get it out of my driveway with making a mess? Cause I won't be shy to charge cleaning fees
Ready yourself.
The PMs are coming
:D
  • 3 weeks later...
Hi guys, quick update. Took the pods off and changed back to airbox and took it for a few runs (taking piggaz's advice). Couldn't really tell if there are any improvements with lag, feels about the same. It's alot quieter though so I'll leave them on for a bit and see. What I did notice is that after the first run I left the car idling for a few mins, then going for another run it felt slight loss in power. It seems that the R34 Gtr power is affected by under bonnet temperature. So perhaps the airbox is better when in stop/start traffic.
Will report back with next mods hopefully in a few weeks, just saving up a bit.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
