R34 Gtr Garrett -5 Turbo Lag, Need Advise
baicai
The most important aspects that the greddy intake kit addresses are the cold side merge before the FMIC, and the tendancy of stock intake (black rubber) to partially collapse and restrict intake.
The intake path is also much smoother for airflow.
Strangely the fixing the merge reduces turbo shuffle but on AFM setups the smoother intake of the hardipe kit has been know to increase it!
If you have a 33 or 34 I would personally recommend keeping the stock airbox, and either modding the stock twin turbo pipe or lashing out on the nismo item.
Intake to airbox can be firmed up be KTS hardpipe kit or one of the reinforced silicon pipes floating around.
For me on my 32, I scored the greddy kit cheap second hand and because I was changing to MAP I could ditch the poxy foam filters for some (larger) quality K&N items.
For the average punter I don't think there's any noticable power/response changes, but intake noise is much more noticeable as is OEM recirc/bov... this is a pro/con depending on your preference.
  • Like 1
  • 3 months later...
Update:
Installed Tomei dumps this week ( Bought HPI dumps but couldn't fit on my R34 Gt-R, 15mm too short, would only fit R32/R33 apparently) and "hi flowed" the twin cats of my Nismo exhaust.
Result:
Couldn't tell that much difference, low to mid range was still laggy like before, not much untill 5k rpm. The pick up might be slightly better but can't say for sure as I've only driven it for a short while.
Best thing gained it now shoots little flames on soft limiter cut. Will be installing intercooler hard pipes next week, hopefully this will make more of a difference.
Update:
Result:
twin cats?
why 2 of them?
I don't want the one I got already lol
who tuned it and what they say it could be
twin cats?
why 2 of them?
Twin cats because it's a Nismo exhaust twin 2.5 inch into 3, still saving up for a bigger exhaust, so this will do for now. Car was previously tuned by JEM and will be on the dyno soon once all the parts are in so hopefully a tune will fix things up a little.
Doubtless been asked and answered but what boost controller do you have. Need to be sure the wastegates are shut unless you need them to be otherwise.
Boost controller are profec B II, not too sure how too adjust it, so gonna leave it to the tuner.
Hpi dumps not fitting is news to me. I bought some that were originally on a 33GTR, bolted straight up to my 34GTR setup (GTX2860's now -5's) no problem.
You sure they didn't try to fit them back to front lol?! as they are different for front and rear.
Shit son, haven't heard from you for a while
  • 3 weeks later...
Bought it from just jap, even they didn't belive me. But putting stock next to HPI and Tomei you can see that HPI was a bit shorter, unsure why, so they happily swap it for me.
  • 1 month later...
Update: Car has been tuned and dynoed.
First run: With only thing changed to the car being tomei dumps and 'high flow' cats. Not much difference at low and high revs, made extra 4 kw at peak, this could be due to change in temp or other variables. But did gain some mid range torque and peak boost happening maybe a bit earlier, nothing spectacular but the dumps and cats did make a small difference.
Second run: Now installed with Nismo hard pipe and Nismo 100mm intercooler, 1000cc injectors, 450L fuel pump. Peak power gained of 17kw to 313kw atw at same 19psi. More power and torque across the rev range, biggest difference is peak boost happens at 4550 rpm instead of 5000 rpm.
Drive: Car definitely feels more more responsive and pulls harder, response is still a bit slow compared to stock turbos but it's much better than before.
Cost: $1000 for every 100rpm of response or $300 for every kw gained, f expensive.
Conclusion: I think we are half way there, next on the list will be bigger exhaust and turbo inlet pipes.
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
