hey stix
im doing identical setup except im keeping stock cooler pipes for the "its bog stock" look. did you need to change to hard pipe or just wanted to for obvious reasons.
what boost did you use for that power on 98
Problem with stock cooler pipes is they pop off with high boost pressure. It was something we had to do. Its sitting at 1.6bar for 402kw max injectors. 1.4bar is what it is set for the street.
ahh bugger the old hose blow off situation . side effects off boosts, was that using stock bovs? or were they blocked off?
ill leave my under tray off and always carry a few tools just in case lol
Actuators are what they came with. Havnt had any problems. Think spring rate is 1bar.
Yeah stock BOV's but they are at their limit now apparently. So if I upgrade my injectors I think they will be required as well.
Forged bottom end and a after market oil pump would be a must for me if i wanted to make the most of -5's.. No point in having -5's if your not going to 8000rpm.
I've seen results from well sorted stock bottom ends with -5's making power without reving past 7500 so when 9's dont cut the mustard theres no other choice really except 5s and chase response.
Oil pump gears are ok but forged bottom end not needed
The problem is there are to many people who want to build an engine because it make 10kw more then factory, when its been proven the rb26 will take over 400kw at the wheels without being forged
+160K stock engine with -5s + Poncam Bs making with no noticeable loss down low compared to previous 34R turbos + dialed stock cams, but big gains in mid/high end.
Upcoming E85 tune will bring even more fun times.
#YOLO
  • Like 1
lol i accidentally quotd myself lol
but in saying that my engine is getting built with Tomei pump and the other usual shit to make the most of the 5's like you said earlier
undecided atm but is on the cards i do know if i go that route ill end up with -10s.
just wanna keep things simple n looking stock. last car i built n tuned myself was tidy as big power and cops f**ked me. so i bought a Ducati 1098s lets just say it turned me of cars altogether for years
Edited by mr skidz
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
