R32-25t is right. Cam gears, compression ratio, changing the engine capacity or putting smaller turbos on is what will increase response. Of course a good tune is always necessary but won't make the turbos smaller, I have -5's on a 2.6. 4500-5 k is where they hit full boost. An on tight corners an tracks I wish I had smaller turbos sometimes, as some corners 2nd gear is too Laggy you can drop it back to first but ur got 6000rpm n close to 400kw on tap which isn't really what u want either. Fast corners or straight lines -5's are great.
can you show me your logged afr numbers on your dyno sheet please then id like to see how your ign values look at the point of on boost.
all camshaft specs?
gears?
exhaust dia?
which injectors?
fuel?
plug type gap?
coilpacks?
is engine warn out most people wouldn't know!
easy to blame a turbo.
there are many factors.
all camshaft specs?
gears?
exhaust dia?
which injectors?
fuel?
plug type gap?
coilpacks?
In the fact that you cant take a blokes word who owns and tracks the setup in question for them being a bit big for a 2.6L. Then wanting to try pulling apart his setup to try justifying his response that's how ;) I'm sorry but the choon ain't gunna make the improvements in boost response like the breathing mods will!
  • Like 1
y not just trying to help him..and im sure others with more responsive -5 set ups will chime in with advice also what's wrong with that we're just here to share ideas and help each other out there are some very knowledgeable people on this forum in different areas for different reasons can't hurt
Edited by mr skidz
I don't understand what there is to argue about though? -7s and -9s spool up a lot earlier than -5s, that's a fact. Therefore -5s ARE LAGGIER. You're interpretation of "How much lag is too much lag", might vary greatly to someone elses in this thread. At the end of the day some people say -5s are amazing, but I'd say an equal amount say "-5s are too laggy for me". Most of the time because these people only drive theirs on weekends down to the shops.
While you are right that a tune can make a massive difference in response (in comparison to a SHIT tune). The size of the turbos still stop it from ever coming near the smaller turbos response time. I have driven, and continue to drive multiple different GTRs on a weekly basis, I will never recommend -5s to a customer with a STOCK motor. While they are more exciting on boost than the smaller turbos, you're not driving above 4500rpm for 99% of your driving.
I also don't want to have to blast the ears of people I overtake because I needed a louder exhaust to make close to 400kw for the street.
Oh the lols
People keep mentioning only driving to the shops on weekends and the -5s being to lagy only for them, that is where matters least, it's on the track that laggier turbos show the weakness
While you can drive it above a set rpm to keep it "on boost" that is only half the story, ever wonder why there are GTRs out there that run 13 second quarters at 140mph, it's because there is also lag between gears and/or if you have to pedal it then there is lag waiting for it to boost up again, this is also true for circuit for ever gear change and when come out of a corner and the back end tries to overtake the front and you have to get off the gas
Most people won't know enough or have enough experience to feel this
Also it has been mentioned about advancing or retarding the cams, this is where twin cams come into their own
What happens if you advance one and retard the other and vise versa
Please note there is no question mark as I'm not asking, I already know the answer
It was also mentioned tuning with EGTs, this is only truely beneficial for tuning if done with individual EGTs, one for each port
This I have never seen done on a true street GTR with factory mount turbos
I also think what Mick-O was saying is if you are taking the car to a half decant tuner and not trying to tune it yourself ( this applies to the average Joe and not people actually capable of tuning ) then taking it to a different tuner isn't going to make a world of difference to turbo lag where mechanical changes can, this also doesn't apply to power at given RPM range but where in the RPM range the turbos hit full boost
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
