Nah just the dirty thirties that keep breaking gearboxes
LOL!!!, *sniff sniff sniff* I smell dirty thirty envy :D
Don't worry and keep trying, you may beat one one day, just remember " I think I can I think I can i think I can" :P
Any gearbox behind a engine pumping the better part of 3x the factory out put is already living on borrowed time no matter if it's a 2.6 or 3.0 :/
  • Like 1
Hi guys
After more research have decided to get the following.
1. Dump pipe: HPI dumps 76mm or Tomei expreme 68mm, which one is better?
2. Manifold: when I get the dumps installed should I also get exhaust manifolds as well? Again HPI vs Tomei expreme which one?
3. Exhaust: Custom twin 3inch with twin cats into 4 inch or twin 3 inch Y pipe into 3.5 inch off the shelf Tomei?
Any feed back from people who have these similar parts would be much appreciated.
Hpi
Stock manifolds. Port match them if you want. I'm making over 470 rwkw through -5's on stock (although tickled to match the ported exhaust ports and match the turbine housings which have been taken out to gasket size) manifolds. The Tomei ones give you nothing apart from a lighter wallet and a sticker. Nice paper weight though when they crack!
Twin 3 inch into a proper 4 inch.
Put the stock airbox back in.
Play around with cams. Advance intake, retard exhaust.
Report back.
That's really as much as you can do before engine out, increasing capacity and the wallet emptying exercise that comes with turning that corner.
  • Like 1
Hpi
Report back.
Hi piggaz thanks for the tip for the exhausts, with regards to the airbox are you saying it will lower the lag a bit compared to pods? And at what power level later on do I need to ditch the airbox?
Well as I said in my PM, I'm still running an airbox at 470 rwkw plus.
Unless the pods are boxed off, I can't help but think about the hot air you're supplying the engine for starters. The factory box has an intake from the passenger guard which is a damn healthy size and the front snorkle. I've always wanted to do a back to back between pods and the airbox but I can't see it being a restriction as yet.
Lots of GTRs running 3.5" without issues, but bigger is better, i would also go 4".
Make sure you have enough ground clearance under the rear subframe and chassis if your lowered and get it tucked up tight to the car, nothing worse than dinting and scraping it over speed humps.
  • Like 1
is your 4" loud? just 2 mufflers?
I have the system they are describing on my 34 and it is quiter then the 80mm Jap catback that came on the car and I have the rear diffuser fitted without having to modify it :thumbsup:
Though for a 2.6 with -5s 3.5" would be plenty
The snorkel from the airbox to the side gaurd will be blocked, pull it out and remove the cap, airbox v pods will have 2/5ths of F all difference to lag, it's the hard pipe bit that bolts to the turbo that needs modifying, that is all I have done to my 3.0 and I have run up 458kws at all 4 with fancy -10s
While we are on the topic of exhausts. I've got hks gt-ss (-9's) turbos going in atm with hks dumps.
Saw a bargain the other week for a full 4" decat exhaust with tuned length front pipes.
I am considering buying it as I have a 3" bolt on jap system with high flow cat and front pipes but the cat-back has 2.5" restrictions inside I believe.
Obviously it will be noisy but I am afraid it will be a bit crazy on the noise scale. Only looking to push like 330kw later on when I do the other supporting modifications.
I can't decide so looking for some input.
Is it worth getting the 4" now (or at all), or safer to stay with the 3" and upgrade to a 3.5" later when I will be pushing to 330? The car is a daily so legalities are another issue.
just remove the 2.5" restrictions for 330@wheels.
Found this about Nismo inlet pipes which says gives better response and boost pick up.
http://www.r33gt-r.com/2011/10/nismo-air-inlet-piping.html
Has anyone installed the Nismo pipes or a Greddy induction kit to their car, feel any difference?
Modify the twin turbo pipe for $50. Good enough.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
