I think you are asking where to get a 4.1 ratio for a gtst - yes?
GT-R = 4.111:1
Stagea = 4.083:1
All the Skyline / Stagea range use the "R200" differential. The whole differential unit will bolt into your GTSt, although I think if you use the Stagea gears, transfer the crown wheel and pinion to your current diff centre (I understand Stageas run an open - non-LSD - diff centre).
Either way, you might need to change the speedo drive gear in the gearbox - a GT-R one swaps straight in.
https://www.sau.com.au/forums/topic/453966-r32-diff-ratio/#findComment-7484235
Thanks jiffo, massive help!
I can get hold of a s14 diff with 3.9 ratio but it's got an abs sensor.
Can u use this diff or even the internals into mine? I am aware I would have to change the shafts. The only thing is the abs sensor.... Looks like the drive shaft is too long.??
Cheers
https://www.sau.com.au/forums/topic/453966-r32-diff-ratio/#findComment-7490804
