Hi Guys,
i just got my first Skyline, and this is my first post on this site,
big thanks to all you guys, i did alot of reading on this site before i decided to do this build
This is the Car
Its a 1991 R32 Gtr
grabbed it of ebay from a retired policeman in Newcastle
its not running, blown turbos,
we towed it back to Sydney and are now in the process of bringing it back to life
https://www.sau.com.au/forums/topic/453974-r32-build-log-my-first-skyline/
Now comes the fun part
im keen on a pretty involved rebuild
and i wanted to get some advice
the build list (so far)
rub back and respray $3500
Rb30 Bottom End $500
RB34 Stroker kit (pistons crank and rods) $5600
borg warner efr 9180 Turbo $3700
Brian Crower BC0230 Valve Springs $500
Hks Camshaft 272 10.2 LIFT STEP 2 $1000
Headwork port and polish $1500
GFB Wastegate $700
ebay single turbo exhaust manifold $700
4 inch turbo back exhuast $1800
Haltech plug in ECU and flex module $2500
im still unsure what fuel setup to install
and i know there will be many many many other parts i will need (happy for any advice)
im not chasing any particular power figures
i just want a good strong car that will be "reliable"
any help will be appreciated
Saw this on ebay. Congrats on the purchase. Looks like a good base to start with.
That's a rare colour so I'm told.
"The factory Pearl Blue is a special order on the V-specs (according to an independent site, only around 300 ever made"
Will it be a period correct resto or balls out build? Either way, looking forward to the end product
definitely like the blue paint and would love to keep it,
i just need to track down the colour,
as for the restore or balls to the wall,
im not chasing a actual power figure, but i want to build a very capable street racer,
low lag, lots of power, (essentially the impossible dream)
i rather have 700 HP and less lag instead of 1000 hp and a lag monster
has anyone used this turbo before, ive been told with the 3.4L engine it should be making 20psi by 3000rpm,
and for the manifold, i just checked for a steam pipe one, that looks really good, thanks for the tip
The Borg warners are fantastic from what i have heard. My tuner has been trying to convince me for years.
I would just make sure you do all the reading in and actually decide on a figure you want. Will help with the overall build.
big thanks Anfanee
i honestly did not know what to do with the gearbox, and ive never seen that gearset before
and that set is really good (smooth and quiet) from what im told, i dont like the idea of a "dog box" or a sequential
i want a regular manual car, that i can drive every day if i want to, no crunching and jerking
so with your help i quickly found this link, the guy from just jap says the gears will hold 800hp ish
http://justjap.com/os-giken-cross-gear-set-nissan-bnr32.html
but i need to get a working R33 GTR gearbox to install the parts in , thats where im stuck
i rang around, there are none that i could find 2nd hand
the only other option i have is to get a R34 GTR gearbox and hope it holds,
but im thinking the gearset might be stronger,
anyone have any experience
... $60,000 build. If you think you will finish it for much less than that your kidding yourself.
...20-25k on a 3.4 stroker engine and bolt on's and you're going to cheap out on a manifold and gate?
Set some goals, set out a budget and build something achievable for you.... a 60% car that runs is a lot more fun than a 99% car that's in bits still.
Cheers
J.
By the way you have written your opening posts, your running head first into it (like we all do).... and I have impressed upon you the scope of a build (in dollars, not to mention the time) you are talking about.
What you have said is somewhat contradictory though... why use obviously cheap and inferior parts for a 'reliable' build, why go a full tilt 3.4lt build for a 'strong car' ... why choose a 1000hp capable turbo that IS going to be laggy- when you're stating '700hp and less lag'?
... so I get to my last comment. Have a little think about what you want out of the car, do the research and choose components based on what you out of your car (as best as you can afford) within reason.
Gearbox... again comes down to what your actual goals are, what you intend to use the car for and what your budget is.
If you want a fast, reliable, easy street car that is very capable on the track... look at an r34 GTR conversion with the stock r32 GTR gearing. If you want to drag race, throw a 2 speed power glide in it.
I do like the colour... have fun with it, because building a GTR is a rewarding experience.
Cheers
J.
GFB Wastegate $700
That's $22,000 plus the price of the car............
I hope you have more success than I do.
I always do my arse on these type of builds.
I genuinely wish you good luck.
Bob.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
