Nissan R32 GTST 1993 2door
MECHANICAL
RB25 series 2 engine
Splitfire coilpacks
RB25 5 speed gearbox
Engine bay mounted intercooler
Jim Berry race clutch with Braided clutch line
2 way LSD
Bosch 040 intank fuel pump
3inch exhaust, hotdog muffler, twin tips
SUSPENSION
Custom crossmember rack moved forward ~25mm
Extended LCA's
Non hicas power steering rack
Tie rod spacers in rack
S14 tie rod ends with longer tie rods
Tein castor rods
HSD HR coilovers
Non Hicas S13 rear cradle
Cusco toe arms and adj camber arms
GTR rear swaybar
R33 brakes front & rear
OUTSIDE
Exterior factory crystal white (326)
GTR Bonnet w/N1 lip
GTR Front bar w/N1 vents
GTR bumper reo
GTR grill
GTR headlights
M spec sideskirts
M spec rear pods
Carbon fibre roof lip
RAYS gram lights 57D 18x9.5+12 painted gunmetal
INSIDE
Apexi Power FC ecu
Eboost street boost controller
Defi' Din gauges (oil temp oil pressure and water temp)
Nardi Classic
Broadway mirror
Rare factory seatbelt holders and factory seatbelts
Great condition dash and trims. All modifications have been modplated and car will come registered. Looking to sell for asking price but I am slightly negotiable.
Phone 0499502000
https://www.sau.com.au/forums/topic/453975-r32-gtst-rb25det-2-door/
  • 3 weeks later...
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
