<500cc Side Feed Injectors - Rb25 Neo
Linnertson
 Share
Oh really? I thought all 25's were side feed. I better have a look then :S Is there any real way to tell, will the injectors be litterly flat to the block if its a side feed?
Thanks fellaz.
I've gone from SR to RB and I know almost nothing about them yet :unsure:
Edited by Linnertson
It's very easy to tell. On side feed rails the injector heads protrude past the rail and are retained with caps. On the top-feed rail of the Neo the injectors are retained by the rail i.e. the rail is the highest point.
The SR uses a side feed rail and it looks similar to non-Neo RB25's.
Edited by colourclassic
  • Like 1
I checked just then and yep, looks like a top feed. I understand now because I know my old SR had the caps so that makes sence, thanks guys all this knowledge helps :)
I dont really plan to run E85 tbh, just because theres no one that close I would fill up on in the north shore (and I do weekly trips to newcastle).
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
