tIt seems that my MAF`s are on the way out . On checking the part numbers it seems that I have Nismo MAF`s 22680-RR580 ,
can i remove these and fit a pair of R34 MAF`s 22680-05U00 .
As far as i know the ECU is stock and there is no piggy back ECU so I presume that other than the aftermarket turbos it is all stock ,
I am running stock boost system to .
Any help would be appreciated as this is my daily driver with the stagea being off the road .my MAF`s are on the way out . On checking the part numbers it seems that I have Nismo MAF`s 22680-RR580 , can i remove these and fit a pair of R34 MAF`s 22680-05U00 .
As far as i know the ECU is stock and there is no piggy back ECU so I presume that other than the aftermarket turbos it is all stock , I am running stock boost system to .
__________________these and fit a pair of R34 MAF`s 22680-05U00 .
It seems that my MAF`s are on the way out . On checking the part numbers it seems that I have Nismo MAF`s 22680-RR580 , can i remove these and fit a pair of R34 MAF`s 22680-05U00 .
Nismo AFMs cannot be run with an unmodified standard computer, likewise you cant replace nismo AFMs with standard ones without retuning.
Nismo ones often come up on here at good prices as people move up to AFM-less computers.
BTW what makes you think the AFM is dying? without monitoring the voltage it can be hard to tell, and its unlikely 2 are failing in the same way at the same time
