Os giken triple plate 1000km old from otomoto suits r33 gtst may fit r32/33 gtr removed from car as im going auto $2200
Arp rb flywheel bolt $60
Will fit r32 gtr-gtst and r33 gtr-gtst
R33 clutch master cylinder $130
1yr old from kudos will fit r33 gts4 gtst
R32 clutch peddle reinforced welds
R32 stock on brakes with heavy duty clutch $50
Over sized slave cylinder from repco same a nismo one with out the $$$$$ price will fit rb25 r33 gearbox $24 1000km old
Gktech clutch line $35 will fit r32-33
Gktech clutch fork pivot $10
Will fit r32 gtr push type clutch
Z32 300zx r33 rb25 box $10
Also have a tailshaft and cross member for are r32 gtst to rb25 gearbox great convertion for a stronger gearbox tailshaft made by ardc drivetrain $900 for tailshaft and cross member / yes its strong handled 600hp
( gearbox is blown you can take it for free strip 3rd gear )
(Dog not for sale)
Nsw
Penrith area
Pm for questions! Or message/call 0422720640 il message back if i dont answer
World Peace
https://www.sau.com.au/forums/topic/454010-r3233-parts-os-giken/
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
