Hi guys,
I've got a used nismo 1.5 way front LSD for a skyline gtr that I've pulled apart to check the plates for wear. There are 8 plates for each side of the diff but There are no spring plates present. Is this normal for the front diff or should there be a spring plate in each cluch pack side?
I cannot find any document or manuals illustrating the assembly, if anyone has any info I would be most grateful.
There are niamo docs for a gtir diff that is also a 160 size but it only has 4 plates per side.
https://www.sau.com.au/forums/topic/454018-spring-plates-in-nismo-front-lsd/
Unfortunately no,
The LSD I have is 38420-RSF16-A with 8 friction plates per side. Nothing on that page matches.
It may be correct, being a front diff having a very low preload due to no spring plates sounds plausible, I just wanted to check before installing it.
Edited by burn4005
