only considering selling or swapping due to baby on the way and in need of something with four doors. For reference, only looking to swap for a manual 03-05 wrx wagon or sedan, or a manual mitsubishi legnum. cash price is 11,500 firm no offers please. rego till 8/5/15.
mature mechanic owner I'm fussy with all my cars mechanically and aesthetically.
basic rundown.
'93 r32 gtst in gunmetal. paint is amazing.
ENGINE:
-series 2 rb25det 160psi across all 6
-rb25det 5 speed
-op6 turbo running 10psi
-walbro in tank fuel pump
-3" turbo back exhaust with varex cannon
-blitz return flow fmic painted black
-nismo engine mounts
-gates racing timing belt kit incl. water pump, rocker cover gaskets and tomei poncams fitted within last 1000km
-hks intake with pod inside factory airbox.
-nistune with base maps tweaked by toshi
DRIVELINE:
-exedy heavy duty clutch
-nismo big bore clutch slave cyl
SUSPENSION AND BRAKING:
-bc gold coilovers
-all adjustable hard race arms front and rear
-r34 gtr rotor upgrade with brand new rda rotors and remsa pads fitted in last 1000km
- genuine SSR koenig 3 piece wheels 18x8.5 +28 front and 18x9.5 +23 rear with 235/40/18 hankook tyres all round less than 1000kms old.
INTERIOR:
-very clean and stock bar an omp steering wheel with nrg quick release
Have yet to find a 32 gtst with factory paint this clean, a mint interior and just all round cleanliness like this one. they're getting rare. There may be more that i have missed, most likely actually. but thats mostly it. located penrith area western sydney. contact zach on 0433 652 959. cheers!
10959506_818085384929673_179400575228298
10984478_818085681596310_334344036345238
10959319_818085871596291_368105827566363
10959690_818085571596321_877331144191995
Edited by the_wolf
  • Like 1
aircon works i regassed it myself about 2 weeks ago (am a qualified mechanic and automotive electrician)
only dyno sheet i have is 181kw when it still had the rb20. it basically feels like every other rb25 that has the same bolt on mods. hazard a guess at somewhere around the 200-210kw mark. the end figure isn't the interesting part anyway compared to the shape of the graph itself...
I only asked dyno figure because it has a nistune, was wondering if was tuned properly on a dyno or just on the street.
I wouldn't expect much with those mods and that turbo,but I have seen too many engines destroyed from dodgy tunes.
Also you said it had cams fitted 1000kms ago,seeing as it hasn't been dynoed, has it been checked with a wideband?
Edited by FBOOST
yes it has been checked with a wideband on the street. toshi did the initial tune on the nistune before the poncams and all is safe since they've been fitted. my current tuner(who is a very good friend of mine) is extremely good and has been tuning cars to an extremely high standard well before i was born. (which was 26 years ago)he knows his shit.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
