Sold my R34 GTT so i have a heap of new parts i never got around to fitting. Send me a message if interested in the parts your chasing. I only have one of everything you see. Mfd has tv button and full harness not cut.
Will post prices shortly.
Exedy heavy duty clutch kit with flywheel.
Genuine z32 bosh air flow meter
Sard 550cc injectors
Nismo short shifter
Tomei poncams type B. 260' inlet and exhaust duration
Tomei fuel pressure regulator
Nismo shift knob.
Nismo high flow fuel pump
Sard fuel rail
R34gtt gauge pillar pod 52mm
Sard fuel rail
Autometer wide band air fuel ratio and boost gauges.
Apexi version 2 ECU and hand controller
6 boost dump pipe and high flow cat with 50mm waste gate adapter
TURBOSMART 2 stage boost controller
All of these parts are new and genuine and i paid big $$ for them but since selling the car they are no longer needed.
Mobile 0419654081 Steve
Edited by stev076vl
https://www.sau.com.au/forums/topic/454032-new-r34-gtt-parts-for-sale/
Where are you located and how much for the clutch?
I'll call dibs if you're in Vic and we can come to an agreeable price :)
Edited by Cowboy1600
  • 3 weeks later...
Location near brisbane QLD.
power fc $900
Cams sold
Shifter and knob sold
Full heavy duty clutch kit with flywheel $900
Nismo fuel pump $350
Mfd and harness $1050 will be shipped to buyer in Germany if not sold locally.AU
550 cc sard injectors $550
Sard fuel rail $250
Fuel pressure reg $80
Gauge pillar pod $120
Z32 afm $250
Dump pipe and racing hi flow cat $300
Will suit t3 t4 turbo
All of these parts came from japan
And are new still in boxes. Dump pipe is used.
  • 4 weeks later...
  • 4 weeks later...
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
