Hi all,
Just wondering if anyone has taken the factory triple cluster in the 32 GTR and replaced the cluster with aftermarket gauges, now before you rage out and rant about searching, im not after the DEFI din gauges.
I bought volt/oil temp/boost gauges and even fabbed up a triple gauge cluster so that it retains as much of the stock look as i could, my question is can i wire them into the standard wire harness that usually connects to the factory triple cluster din? Obviously the boost gauge will get its own line going to the boost gauge control unit on the firewall.
Has anyone done something similar again WITHOUT using the DEFI sending units or DEFI gauges.
Here is a photo of the cluster i found on google, again mine has factory reading gauges not the AFR, Oil Pressure.maxresdefault.jpg
https://www.sau.com.au/forums/topic/454033-r32-gtr-custom-triple-cluster/
Hey Cardo
Voltage gauge should at least give a reading. Boost gauge needs to go to the map sensor that came with it if there was one.
For oil temp you could attempt it to the stock wiring. It should at least give you a number.
Plug in the laptop and compare the laptop oil temp to whats on your new gauge, if it's the same, super happy bonus for you but even if it was off by ten degrees,
If you learn what you're oil "normally" gets to you can spot overheating just as well as if it was accurate. For example if it always showed 92 degrees oil on the highway and one day it showed 120 something's up. Just set your alarms up and wait for a red.
When wiring stuff like this in the dash either leave a bit of length on the plugs you cut off or tee into the wires rather than cutting them, that way the factory stuff can always be put back later.
  • Like 1
Attached are my actual photos.
I have the senders for oil temp and boost, but i was thinking since the gauges are all electrical i should just be able to use existing power lines to the factory cluster and solder them in place ( T style so i dont cut the factory harness up too bad ) once ive found if its a viable option or not.
As far as whats normal haha the factory gauges dont really give the best indication of whats what. i just know the needle points to one line above 70 in oil temp and goes above it slightly at running temps. and boost go past the +7 so i have no idea there, im assuming factory is 14 psi from what ive read with boost restriction removed as mine is bone stock. so as far as normal for oil im assuming its around 79-86 degree mark.
by the way thanks for the reply i really appreciate it.
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
    • It was gonna take much longer for the 440cc so I'd thought I'd risk it with the 550cc. They finally arrived and I couldn't wait any longer (I could but I was quite excited after 2 months) and installed them myself. Removed the old injectors, inserted the new and connected everything up. Before starting the car, I tuned the injector size from the factory 270cc to 550cc using Nistune.   This did some of the calculations automatically which catered for the TIM. The latency however did not seem to change. Deatschwerks have the tuning data available for each injector online, and I had a look at it. It has a table which relates to latency according to pressure and voltage (see below image). Nistune requires the 14v value, but I am unsure of which pressure value to look at (my lack of knowledge and experience have something to do with this). The highlighted value is close to my current latency which is 760µs. It is for 14v which makes sense, and the pressure is 31.6 Psi.   I still gave the car a test drive to see how it goes, and honestly it has never felt so powerful before (and some people say the RB20DE is very weak?). I really enjoyed the drive. Side note; The injectors are quite noisy, which someone mentioned before. This does not really bother me however. I will still ask my mechanic to have a look at it and perhaps ask a tuner to fine tune it if they have the knowledge.
    • Also true. But imagine not wanting new injectors? Imagine wanting to use 30 year old injectors?
