Hi,
The Car is a 1996 R33 GTR Skyline V-Spec
In Adeliade
Always serviced and well maintained
Looked after by boostworks
just had them look over the car for any problems before selling and all came back good
Unlike most older GTRs there is no need to worry about the engine failing or factoring a rebuild etc as it has already been done and maintained by boostworks.
White
Forged Engine
Forged Pistons
Multilayer head gasket
ACL race Bearings
Huge Extended Sump
New Rings
Honed Bore
New R33 Crank
New Rods
Only around 20000 kms old
NPC 5 button clucth almost brand new
New bosch 1000cc injectors
New E85 Walbro Pump
Apexi pods in custom air box
Custom cold air intake
Power fc and controller
AVCR Boost Controller
JUN cam gears
Apexi front pipe, high flow cat and Titanium expreme exhaust sounds awesome!
Garrett -5 turbos
z32 afms
Apexi 100mm intercooler
Coilovers
series 3 front lip
carbon GTR wing plates
Carbon pillar
new gear and handbrake boots
Catch can
Apexi Boost gauge
White Nismo Triple Gauge and Nismo 320kph dash
R35 GTR rear badge
Enkie 10.5 x 18 +12 all round rims with excellent tyres and red light weight wheel nuts
Clear front and side indicators
CD player
Standard clean interior
Long Rego
Car currently makes 387kws at the wheels
Can make more but its my daily and never had a need to push it any further.
Runs and drives great. Clutch is easy for city driving.
Never had a problem with it apart from replacing the clutch
There is a dent on the roof which was there when i bought the car
Runs on E85 but simple tune to take it back to 98 petty
Will take off $1100 if you bring your own wheels
Will take off $1000 If you don’t want the titanium expreme cat back. Will put the stainless steel exhaust back on.
Probably missing other bit and pieces
$27,500 ono
any questions plz ask
https://www.sau.com.au/forums/topic/454161-r33-gtr-forged-engine/
  • 1 month later...
Just had the car in to be checked over before sale, had a compression test came back excellent, had a camera down the engine and again came back fine. Had both turbos looked over and again tight. And a tidy up tune done. So running perfectly.
want this sold!
  • 3 weeks later...
  • 3 weeks later...
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
