Heya guys & girls!
Just hoping if anyone is able to help me out here.
I have 2x fairly decent and not so old split systems at my current place which I would like removed and re-installed at my partner's property.
I've called a few air conditioning guys however they want either the same price as a new air conditioner or refuse to do the job.
So just wondering if anyone can help me out (cash & beer of course :))
I'm located in Canley Vale, NSW
Cheers!
How are your current ones installed?
As in is the outdoor unit on the same wall as the indoor unit?
Will they be installed in the new premises this same way?
Or is the outdoor unit a little bit away from the indoor unit?
Im an electrician working for an AC company. I do installs, repairs etc...
Also what you are wanting is basically a new install plus removal, so yes most will charge you a new install price, there are ways of saving some money by reusing what materials you already have it all depends on install type.
Pm me if you want to sort something out to save some money.
sounds good, I will PM :)
They're both 7 year old Panasonic Inverters and installed back to back at a fibro house atm.. it will then need to be installed back to back at a brick veneer house.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
