Hi Everyone,
I was told on my last tune that my oil pump was starting to get a bit lazy at idle, its fine when it's got some revs behind it. What are my options here, I was told to try run a thicker oil or is it worth investing in a genuine/aftermarket oil pump? What are some good oil pumps to suit an RB25DET NEO?
Current car stats: 1998 R34 GTT 300hp on 13psi
https://www.sau.com.au/forums/topic/454165-lazy-oil-pump/
Thicker oil.
What gauge were they using? I hope not the stock one.
Also it tends to be the engine worn out dripping pressure rather than the pump went out.
this and this.
but also, have you had the motor compression/leakdown tested? If the motor is too tired putting a highflow on it and upping the power a lot when the motor is potentially really tired will just result in a dead motor eventually (and poor results from the modifications).
https://www.sau.com.au/forums/topic/454165-lazy-oil-pump/#findComment-7486654
wouldn't hurt to do a leakdown test in the future but right now for the mods the car has its making the right amount of power so I am not to concerened about the engine being really tied. My guess is I need to run a thicker oil as I gets thiner as it heats up.
https://www.sau.com.au/forums/topic/454165-lazy-oil-pump/#findComment-7486694
Thicker oil.
Its not particularly easy to replace the pump, so I would be trying thicker oil first.
100% right.
DoseV, since you dont know what oil is in there now, contact the shop that did the service to find out what they use. If that doesn't work just get an average price dino first while you're trialling viscosities to see what works. Maybe assume they used a ?w-40 and try a ?w-50 first.
Once you've settled on a viscosity that works, step up to a good full synth and go the full 5000kms change interval.
https://www.sau.com.au/forums/topic/454165-lazy-oil-pump/#findComment-7487701
So what oil pressure readings are you getting to call low?
10PSI for every 1000 RPM is all you ever need......
If your seeing 60 PSI or over at 6000, your good for 6000RPM, over 30 PSI at 3000, and so on.
Dont trust the factory oil pressure senders, make sure its aftermarket and post your results at each 1000 RPM.
Usually its worn bearings rather than worn oil pump giving the low readings unless your pumps bypass valve is stuck open or the pumps seriously worn and damaged.
A thicker oil will mask the issue.
https://www.sau.com.au/forums/topic/454165-lazy-oil-pump/#findComment-7487843
100% right.
id assume any shop would do the easiest thing and just read the manual and put in the factory rec of 30w.
https://www.sau.com.au/forums/topic/454165-lazy-oil-pump/#findComment-7487975
I'm struggling to believe a tuner bothered hooking up an accurate gauge onto your engine.
Can you confirm with them how they can to the conclusion of lowish pressure?
I doubt they did as well my guess is the oil in it now is way to thin thus making the engine a bit noisy once the oil is warm at idle. But any way the car is going for a retune and full inspection in 2 weeks.
https://www.sau.com.au/forums/topic/454165-lazy-oil-pump/#findComment-7490769
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
