interesting then cause ive got a 3inch jap muffler sitting in shed, sounded pretty angry on the rb but quiet on idle and cruise, be interesting to fit it up, pitty I cant weld myself cause exhaust shops are a rip off,
the cannon could be hidden from view so wouldn't be seen, just a 3inch pipe
so to clarify is the exhaust size universal, eg 2.5inch gets your 250kw, 3inch for 300kw etc as a rough rule?
Well, no. First up the LSx exhausts are typically twin systems and so 2 x 2.5" (~39 in2 area) is a fair bit more flow than 1 x 3" (~28 in2 area) Skyline system. Also the (catback) piping itself is often not the restriction, it's the other bits like cats and mufflers. Stock headers can also restrict flow if you're running big numbers.
Whilst thats completely true (its maths!)
Is the flow really required? A 3inch straight through muffler probably flows more than the stock rear dual resonator.
I'm sure I've seen flow calculators online for exhausts. It would be very interesting to see what an ls engine can flow through the stock exhaust.
Having to pay a shop to do it does suck. That's where I'm lucky having the equipment to mess around with an exhaust to get it where i want it.
Pipe Diameter (inches) Pipe Area (in2) Total CFM (est.) Max HP Per Pipe Max HP For A Dual Pipe System
1 1/2 1.48 171 78 155
1 5/8 1.77 203 92 185
1 3/4 2.07 239 108 217
2 2.76 318 144 289
2 1/4 3.55 408 185 371
2 1/2 4.43 509 232 463
2 3/4 5.41 622 283 566
3 6.49 747 339 679
3 1/4 7.67 882 401 802
3 1/2 8.95 1029 468 935
Thanks Ben C34, let's try this table again:
I see where they're coming from but I would still take the HP readings as indicative only.
For instance, I'm running 285 rwkw without air filter or lid. This is about 380 hp in the old money. Assuming 20% driveline loss would make this 475 hp at the engine. This is all through a 3" turbo back exhaust system - yet the table above suggests Max HP of 339 for this pipe diameter.
Now it's all getting awfully academic :)
Fuel and boost also make a difference to the pipe diameter required.
At the moment I make close to 500HP at the engine on E85 through a 3" pipe but that doesn't mean I can't make more by going bigger.
For 250-300rwkw on an LS1, a single 3" pipe would be fine.
  • Like 2
I had a similar conversation with a c63 owner, he was fitting an Xforce twin 3 inch system (don't know why, don't ask) and was told the 100 cell race cats I fitted had to go, his tuner said they would make the car detonate.
The exhaust would have been good for 600+kw ffs.
Bloody mail order tuners.
  • Like 1
I love my twin 3" DPE on my LS3
Sounds excellent... And of course drone @ 80km/h in 6th, that's just a given.
Note definitely changed after the first 200km too, much deeper... That said I got it REAL hot fast, most would probably take 1,000km to do that.
so do they drone less after a 1000km's? Might be worth leaving it on for a few thousand km's if its going to get better, the sound I thought it was going to make was the sound that it made with the resonator taken off the back , so just the 2 center mufflers and open at the diff, nice and deep, meaty.
and yeah drone is at that 1300-1600rpm, right where the auto likes to be on a cruise.
Edited by AngryRB
You're comparing thrashing and getting the exhaust really hot and bedding in, to driving around the street like a normal person. The exhaust will take longer than 1k to bed in.
Nice system, it's the one I would have got had I a spare 3k at the time.
You can't really lose with a bigger exhaust for an LS - for me its just ground clearance that is the issue! Single 3" will sound like shit and will be a restriction btw.
On the Di Fillippo website it actually talks about how they typically reduce the pipe size after the diff to keep gas speed up and that's what creates the best sound, but my catback system is 2 1/2inch to the tip,
I had a worked VS ute before this one, had stroker, cams, diff gears, 3inch exhaust but only a 2.5inch tip pointed to the ground, every time it started it was like the world was about to end, could hear it from blocks away,
I'm gonna just run it for a few thousand km's, drive it like I stole it lol :yes:
  • Like 1
Anyone know much about extractors?
Im stuggling to decide wether to get TRY Y 1 5/8 with 2.5inch outlet OR 4 into 1, 1 3/4 with 3inch outlet...
A few things ive read are that the 4 into 1's will give it a great V8 beat to it but may loose torque on bottom end, other people say that when the car is tuned you wont loose bottom end but gain everywhere and just to choose for sound?
If the difference isn't that noticeable then im thinking the big 4 into 1's look the business.
have you tried the two on the same car? Ive asked quite a few exhaust shops and they cant give a definite answer, I spoke to Hi Torque Performance, and he said the 4 into 1 will be fine and they don't lose any bottom when tuned??
but need more opinions before spending this amount of money...
    • I'd need to check my notes at work Duncan, but I'm pretty sure most of that is purely OBD2 on the display. How quickly is it all able to update? Do you have any internet capability in your workshop with a laptop?
    • Yeah just gonna be near stock runner only want 180kw to 210kw can’t find anything been looking ages looked in to rb25 but money is tight as the moment need the car back on the road
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
