Highing flowing Injectors Good or Bad??
well I have heard of hiflowed injectors being checked and they had a huge difference in flow for each injectors if you can't afford the proper injectors you can't afford the up grade. raising the rail pressure will get you a higher tolerance of power I would do that b4 hi flowiing injectors or even use r x7 injectors as tony said.
there is no cheap way to get performance
btw note you said the approx flow rate is 590 cc you buy a nissan sard apexi or denso injecotr and they tell you exactly what they flow not approximates.
how big is your turbo stock injecotrs can support p 400 hp @ the fly wheel when the pressure is raised
meggala
Guest darrinspencer
meggala
They are 590cc each. was told they would be within 1cc of each other. I should not have used the word "approx"
The same guy told me to be aware of Sard injectors from his experience he has had too many failing to reach there specified CC rating.
The only RX7 injectors that are side feed for the rb25 are 13b S6 or cosmo or 20B primaries.
Try finding them under about $200 each!!! second hand $1200 set of 6. I have.
To use top feed rx7 injectors requires a new fuel rate etc. more cost.
I am actually seriously considering going down this path, I can apparently get it done for around $200 for all 6 injectors through a connection I have.
When I get around to having it done, after I will get them flow tested and post up the results. That way we can have some solid data on the benefits, if any.
Adam
Well, according to SK in a previous thread, proper hi-flowing costs about $200 per injector -- a little less if labour is free -- and on that basis its cheaper to buy new ones.
http://www.skylinesaustralia.com/forums/sh...19&postcount=15
Haven't been able to find the thread warning against hi-flows yet (as per Megalla's post).
LW.
I seriously doubt that :( :Oops:
Wow... A member of the automotive industry putting a bad word on a competitor's service/product?!?! Well I'll be!!!!!!!!!
Bottom line is, high flows are made by attacking the injectors with a drill. Ask him for a 100% MONEY BACK guarantee of a 1cc difference across the range of injectors, to be tested by an independant source, and see what he says :)
Even new injectors have upto a 5-6cc difference across the range. You can tune this out via a programmable ECU like the PowerFC, or fit the higher flowing ones in the leaner cylinders.
If your budget can accomodate new injectors, go for it...
If not, I suggest second hand injectors of your required size and have them ultrasonically cleaned and flow tested...
If you're building an "N1" spec car like Dundan, then I guess you have no choice but to take a gamble and get your injectors drilled out, but that would be the last option on my list :spcow:
Guest two.06l
so that comment would mean that all nippon denso injectors are unreliable as the brand name SARD merly applies to the box they came in .Nearly all aftermarket japanese injectors are made by nippon denso to be resold by these companies eg.hks sard nismo etc
Thats a very good marketing tool, call everyone elses product shit and then claim 1cc difference between the products you butcher/highflow :cheers:
Guest two.06l
Thats a very good marketing tool, call everyone elses product shit and then claim 1cc difference between the products you butcher/highflow :D
someday people will realize that this industry is full of fallicies and old wives tales(read:bull5hit).Unless i see or prove something with my own eyes or have the info coming from a trusted and/or reliable source it cannot be trusted. There is nothing like the self satisfaction of proving results for yourself.
Guest darrinspencer
The company offering to do the work are a "Advanced Performance Centre" without mentioning names
They build plenty of fast cars to PROVE their work
9.97 GSR and
Australia fastest front wheel drive CRX
Just to name a few
So I can only assume they know what they are talking about.
The very same can be said about internet forums.....
Adam
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
