Hey guys quick question stupid me.
for some reason my R33 gtr seems to not have the "Standard Brembo factory" brakes. mine have nissan ones.
were brembos factory all round.
also my R33 was registered as a 1997 R33 gtr.
97 should be around when S3 where made.
But mine is clearly a S2 i knew this upon purchase but just seems odd that a 97 mine is a S2 not a S3 unless it was made just at the start of 1997 before S3 came along. can anyone confirm the exact date/time they started S3 production? Could mine of been a in the middle of S2 and S3.
  • VIN: 6U900BCNR33042576
  • Vehicle: NISSAN GTR 1997, SILVER OR CHROME
  • Type: CAR/SEDAN, CAR / SMALL PASSENGER VEHICLE
  • Registration: VIC, [no rego plate data] expires [no rego expiry data]
  • Engine: RB26058254A
  • Compliance date: 2003-03
Unregisterd at the moment.
https://www.sau.com.au/forums/topic/454216-help-r33-gtr-brakes/
1/96 - 2/97 Is the build date for S2 GTR's.
2/97-5/98 is the build date for S3 GTR's.
There is differences between them if you don't know them. All R33 GTR's came factory with Brembos.
Only the R32 GTR came with standard Nissan brakes except if you have a R32 Vspec that is when they brought in Brembos.
To me it seems like the previous owner sold the brembos off as they can sell for a fair amount as an upgrade to other vehicles. But I am unsure why they would put just standard Nissan ones on as they are a downgrade. Probably to sell the car off and make money, not entirely sure on the reason behind the previous owner's actions though.
If your spending a bit of coin on upgrades (that is why we buy these cars) then I would suggest looking at getting some Brembos to begin with or if you have deep pockets you can buy some better kits starting from a few thousand.
That VIN was build in 10/97.
I agree, most likely the person you bought it from pocketed the $1000 for downgrading the brakes :thumbsdown:
Having said that the 32 brakes are fine for street use, and Ksport/ATTKD etc make good upgrades from about 2000
10/97 Would definitely be a S3 GTR. There are a few differences between series two and three.
The obvious one is the interior is red instead of blue but it could have been re-stitched.
A check you can do is with the rear of the car. The outer tailight of the set should only light up unless modified. And you will only have one reverse light on the left as the right side has a fog lamp, which is an orange kind of lense.
Found out its a common thing for people trying to get the most out of them when selling/ also happens at the auctions/docks in japan.
and if you got it for the price i did for the condition the body is in. and the engine leak down test/compression test results and also gear box after i fixed the clutch adjustment. you wouldnt care what brakes where on it. when im going to upgrade them anyways. i was just curious.
  • 6 months later...
I also have a s3 r33 gtr. I have brembo front calipers, but annoyingly have Nissan rear calipers. I assume the rear calipers were swapped for cash or whatever but the rest of the car is mint so the quest continues for original brembos [emoji4]
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
