Yes but some how your SS2 is god like haha
I still don't understand how you managed to make 324kw on 16psi, it's just insane.
Depends which turbine wheel it has, Tao is using near GT35 sized wheels in the SS2 these days so I would expect it to flow well.
I went ATR45SAT from Stao - Supposed to perform well on restrictive systems. I ended up buying a different actuator though so I can get it down to lower boost pressures. The actuator that comes on it is a 20PSI one and I doubt the stock motor would be very happy with that.
  • 2 months later...
Is there anybody who has tested/used the pwr r34 intercooler. I'ts also a return flow setup but i gues, that a brand like thid will not make something that will give flow restrictions, at least not at that price ...
This is the one I mean: https://www.pwr.com.au/wp-content/uploads/PWI2204-Skyline-R34-GTS.jpg
stock motor loves boost (when fitted with proper head studs)
spent all Sunday abusing my car at Wakefield in 40 degree heat and then drove home. Motor still pumping on!
  • Like 2
As I have said before, it does not matter how good the core is when the end tanks (well, mainly the return flow end) suck testes.
Nah, don't think that's the problem because a turn wil not let drop you pressure, the core himself gives a lot more resistance then a turn in a decent diameter could do. You see lots of people who fabricate there own return flow'ish piping with a 180 degree radius directly after the cooler, so that should give you the same issue then a turn Built in the end tank ... Not talking about the phenomen that the isue is mush bigger on a neo engine
Hks made one with the 180 bend. I was going to make one and did a bit of work and was very easy to do. The only problem was it was either too low or it sat against the radiator.
I honestly can't see or have found a good explanation on why a return flow is a restriction.
I'd believe GTSBoy... But if you need more info. This page has more info than you could ever want on intercoolers.
http://www.are.com.au/techtalk/intecoolersMR.htm
My new intercooler is an ARE, given the information they've put together on that page, they clearly know what they're talking about.
Ok rhen you'll be kowinng what you're saying :-p
But i personaly don't see the the difference, can you explain why you're not having the same isue if you're fabricating a 180 degree turn directly after the end tank. Because of you look at the blitz, it's just like they have 'welded/extruded' the turn just after they bring the air together in the end tanks.
It's not so much the 180deg bend as it is that it turns on such a tight radius, if the 180deg bend was around a 300mm radius the issue wouldn't be so bad but most return flow intercoolers have the 180deg bend inside a 100mm radius which with air volume and velocity trying to get the air to change direction causes turbulance which creates a high pressure area inside the bend that restricts flow
A crap cooler core runner entry design will also add to the issue
Now I'm only a machine opertator so that might be wrong but that's my understanding of it
  • Like 2
^ This is pretty much it. It's not just the tight radius. At least with a bend to make the equivalent of a return flow cooler, it is made out of pipe, so has a smooth pipe to flow around the 180. The exit from a typical return flow tank is just shocking, basically just a 90° sharp corner off the end of the tank, and that's after the air has already had to turn 90° off the end of the tubes.
On top of that, the core is only ~75% the height of a full cooler because the return pipe either goes above or below the core. So you will run a higher pressure drop across the core itself at any given power level.
Don't get me wrong, I don't have a vendetta out against return flow coolers. I have one on my car and have done so since last century. Just pointing out that there are real reasons why they will hit the wall before a normal cooler will.
  • Like 2
One thing is sure, lot's of people refer to the shorter piping, but imho, if you make you're piping decent, like for instance a plazmaman piping kit, i don't think piping will be that much longer
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
