And yet Kinkstaah made 400kw through a Blitz return flow on his 34... It's easy to blame certain parts, but a 180 degree bend isn't going to hold you back 50kw unless it has a rag in it.
  • Like 3
  • 3 months later...
I have the blitz return flow and had unexpectedly low power figures comparatively with similar non return flow based setups. Haven't had time to isolate return flow as the issue yet.
Only seems to be an issue on 34's, but what are the actual differences between the two RB25 motors that would make any discernible difference? I realize the combustion chamber is smaller, could it be carbon buildup? Or perhaps the traction throttle plate is closing causing lower power figures? Tao is trying to get to the bottom of it too.
Unfortunately if you don't want a return flow, and you don't want to make your car defectable by cutting holes, you will need custom piping with a cross flow cooler. (either up past the radiator or u bend behind the cooler.)
  • Like 1
I'm scratching my head a bit with my R34 as well. With 3" exhaust and standard SMIC it was well down on power, VCT seemed to make no difference between 4000 and 6000RPM, and it just wouldn't take any timing.
Since then changed my coil packs to splitfires and put a Blitz return flow in and I have cranked in 6 degrees across the board without any pinging issues, and the car now pulls WAY better. Boost is untouched on 10psi (logging MAP afterwards indicates almost no change).
Boost line is off the compressor elbow. So if the previous SMIC was a restriction it should have dropped pressure across it (and the FMIC should show more at the manifold). But that's not happening.
Maybe it's air temperature related? R34s get pingy once the intake temps go up? Or maybe my previous coil packs were causing pinging (sounds odd I know.. but I DID have 2 intermittent coils)
Hmmm looking at buying one of these return flow Blitz coolers butt looking here seems like it isn't going to work for me adding up to my 300rwkw mark hmmm would someone recommend maybe HDi ive heard good things about them I just wanted something that would fit without cutting holes but looks like it isn't gunna happen.
The china spec return flow from Just Jap held 320rwkw for me on 22psi so maybe have a look at that. I don't know who else is using it but I haven't had any problems with it
Brennan can you link us I can't see it on JJ
It would appear they don't sell the exact model I have but it is essentially this cooler, with the return style piping kit that they sell separately
http://justjap.com/engine/forced-induction/intercooler-kits/cooling-pro-type-1-intercooler-kit-nissan-skyline-ecr33.html
If the link doesn't work blame my phone
  • Like 1
Blitz should do 300 easily on a 33, only 34's seem to have some issues with them, but it is obviously something else causing it if they work fine on some cars not others.
The stock cooler will flow 250kw, how can a Blitz be no better?
Cutting holes isn't the answer. Get custom piping made for the cold side if you go for the HDI.
  • 1 month later...
Word on the street is the newer blitz Se return pipes are smaller diameter than the older ones
Not sure on truth. I'm still
In the process of running tests with a cheap JJR return flow kit
Edited by Therealsandybang
  • 1 month later...
Scott - What do you mean custom piping made? Piping that doesn't require cutting the frame to get the IC pipe up there :O
There is enough room usually to get 2.5 inch piping up past the radiator, if you cut the shroud a little.
You can also run it behind the intercooler and back to the factory piping. No need to make your car defective these days, especially if it has an airbag as it can't ever be engineered.
That would be awesome! Obviously need custom pipework though.
I wish you lived in Sydney or I lived in Melbourne.
  • 4 weeks later...
I ordered a Blitz Cooler heard a lot of good things about them I like the choice of not cutting holes yes I know I have to trim the reo bar but hey everyone loves a trim.
I got the cooler just have to fit it im looking by the end of my mods an easy 300rwkw not going to go over that just want 300rwkw street driven so should do fine.
Im running a plazmaman entry level front mount with custom pipes that join to the standard return flow setup.. it made 324kw with 16psi at 4krpm with very little drop in psi and faulty coils and maxed out injectors on e70.. where is my previous setup made 265kw on 18psi at 4.1krpm dropping 3-4psi with a cooling pro bolt on kit which was causing restrictions past 265kw on 98
Yes but some how your SS2 is god like haha
I still don't understand how you managed to make 324kw on 16psi, it's just insane.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
