Yes but some how your SS2 is god like haha
I still don't understand how you managed to make 324kw on 16psi, it's just insane.
Depends which turbine wheel it has, Tao is using near GT35 sized wheels in the SS2 these days so I would expect it to flow well.
I went ATR45SAT from Stao - Supposed to perform well on restrictive systems. I ended up buying a different actuator though so I can get it down to lower boost pressures. The actuator that comes on it is a 20PSI one and I doubt the stock motor would be very happy with that.
  • 2 months later...
Is there anybody who has tested/used the pwr r34 intercooler. I'ts also a return flow setup but i gues, that a brand like thid will not make something that will give flow restrictions, at least not at that price ...
This is the one I mean: https://www.pwr.com.au/wp-content/uploads/PWI2204-Skyline-R34-GTS.jpg
stock motor loves boost (when fitted with proper head studs)
spent all Sunday abusing my car at Wakefield in 40 degree heat and then drove home. Motor still pumping on!
  • Like 2
As I have said before, it does not matter how good the core is when the end tanks (well, mainly the return flow end) suck testes.
Nah, don't think that's the problem because a turn wil not let drop you pressure, the core himself gives a lot more resistance then a turn in a decent diameter could do. You see lots of people who fabricate there own return flow'ish piping with a 180 degree radius directly after the cooler, so that should give you the same issue then a turn Built in the end tank ... Not talking about the phenomen that the isue is mush bigger on a neo engine
Hks made one with the 180 bend. I was going to make one and did a bit of work and was very easy to do. The only problem was it was either too low or it sat against the radiator.
I honestly can't see or have found a good explanation on why a return flow is a restriction.
I'd believe GTSBoy... But if you need more info. This page has more info than you could ever want on intercoolers.
http://www.are.com.au/techtalk/intecoolersMR.htm
My new intercooler is an ARE, given the information they've put together on that page, they clearly know what they're talking about.
Ok rhen you'll be kowinng what you're saying :-p
But i personaly don't see the the difference, can you explain why you're not having the same isue if you're fabricating a 180 degree turn directly after the end tank. Because of you look at the blitz, it's just like they have 'welded/extruded' the turn just after they bring the air together in the end tanks.
It's not so much the 180deg bend as it is that it turns on such a tight radius, if the 180deg bend was around a 300mm radius the issue wouldn't be so bad but most return flow intercoolers have the 180deg bend inside a 100mm radius which with air volume and velocity trying to get the air to change direction causes turbulance which creates a high pressure area inside the bend that restricts flow
A crap cooler core runner entry design will also add to the issue
Now I'm only a machine opertator so that might be wrong but that's my understanding of it
  • Like 2
^ This is pretty much it. It's not just the tight radius. At least with a bend to make the equivalent of a return flow cooler, it is made out of pipe, so has a smooth pipe to flow around the 180. The exit from a typical return flow tank is just shocking, basically just a 90° sharp corner off the end of the tank, and that's after the air has already had to turn 90° off the end of the tubes.
On top of that, the core is only ~75% the height of a full cooler because the return pipe either goes above or below the core. So you will run a higher pressure drop across the core itself at any given power level.
Don't get me wrong, I don't have a vendetta out against return flow coolers. I have one on my car and have done so since last century. Just pointing out that there are real reasons why they will hit the wall before a normal cooler will.
  • Like 2
One thing is sure, lot's of people refer to the shorter piping, but imho, if you make you're piping decent, like for instance a plazmaman piping kit, i don't think piping will be that much longer
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
