17 minutes ago, Dose Pipe Sutututu said:
It's not so much the FMIC can go above said power levels, it's more so you need to look at how effective it is at cooling the charged air and how much it can flow. Looking at HP ratings manufacturers randomly put on them is trivial.
Standard fuels have much less knock resistance than say E85 or PULP w/ water meth. Hence will knock much easier, running E85 your intake air can be close to 100 degrees without you running into any issues where as if you were just on 98RON you'll run into knock, etc.
Almost as trivial as bolting any fmic to the front of a skyline and just expecting it to be efficient. My cooler is fully ducted and also performed well on PULP. A bigger, better fmic will make up for the fact you have poor air flow through the cooler like the "swinging in the breeze" fmic installations most skylines have.
What are you IATs like on a 3rd or 4th gear pull on a dyno or road? Without data it's just an opinion.
(You nearly sound defensive)
Most return flow cores have quite a bit of pressure drop, I've witness this on a car I tuned before which had a boost source nipple on the charge pipe from the turbo (from aftermarket pipe work) and one tapped into the post cooler side (used for his EBC). There would always be about a 2~3 PSI difference consistently.
Yeah of course it's just my opinion. Just lke you have yours. I'm not disputing anything that you've said.
I'm also not saying it's the best solution or what I'd chose if i was spending the money again now. I wasn't even dreaming of 300rwkw when i purchased it!
However it works reliably for my set up and power level so it can work for others too.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
