I have been on the hunt for a cheaper alternative for some thermal shield and decided to try this stuff. Being the datalogger type I have been measuring the outlet temps from my Hybrid Monster FMIC and was very happy, until I put my hand on the crossover pipe and feel the temp after a hard run. All that FMIC cooling goodness wasted.
This Flashtac product is available at Bunnings and maybe other hardware stores and cost about $20 for 10m. It is a layer of aluminium strip, thicker than foil and backed with a tarry adhesive substance. It did all of the piping required.
I'm also a tight bastard so I preferred to weld up my own FMIC piping from 2.5" mild steel instead of ally or stainless, at least until I have my setup complete to my satisfaction. With my fetish for a twin turbo RB26 setup not yet fed, the FMIC piping is still temporary.
The downside of mild is the rust, so unsightly and unprofessional so here comes the fix. The flashtac is shiny (bling bling) for the looks department, as well as rejecting radiated heat.
I removed the front bar and set to work with a wire brush to remove some of the ugly rust. Then I gave it a wipe down and out came the flashtac.
I pulled off the crossover pipe to wrap it as this one gets the most radiated heat so was most important. Just a slight overlap as you go along is ideal and work it flat along the way to get the look. To obtain a much smoother look rub it in with a glass bottle (beer :D).
Then the inlet and outlet get done on the FMIC as they are visible and that is way uncool to have rust on. I know, ponies before chromies but you gotta maintain some respect.
Then back on with the front bar and happy days. No more rust and a really cool race cred finish to your FMIC piping.
Now the crossover pipe just gets a little warm instead of hot to touch and as all Engineers know, thermal energy transfer is a logarithmic function dependent on the temperature differential so this is not a wasted exercise as the pipe is much cooler even if still *warm*. I would normally measure temps and stuff but the fingers are sensitive enough to tell the difference here.
An afternote is that the tar adhesive does get tacky in the warm engine bay, but I am yet to see any actually melt out from its location. I bags NOT removing it from the pipe ever as it will be a solid gold Biatch.
Enjoy in moderation. I take no responsibility for anyone silly enough to put this on their bling bling expensive polished piping as there will be a massive effort to clean off.
DO NOT PUT THIS ON EXHAUST PIPE, please!!
https://www.sau.com.au/forums/topic/45426-thermal-shield-for-fmic-pipes/
  • Replies 45
Thanks Paul. Really noticing the heat difference after driving. The cold off boost air keeps it pretty cold to the touch. Who am I kidding. Even on boost the FMIC is so big it maintains to within 1 degree of ambient temp. Warms a little after sitting though.
As an update. The tar backing is not leaking out at all after hours of driving (Winton and return) or a 20min hard session through twisties. I am really impressed and the guys who see it immediately think race car.
That Flashtac stuff is good. It survives for years outside on corrugated roofing iron which can be in continuous direct tropical summer sun, and is supposed to be waterproof in winter. Should work well either under the font guard or in the engine compartment.
Another way is sponge neoprene sheet, like the stuff wet suits are made from. Available from Clark Rubber in various thicknesses, glued directly on to the intercooler pipework with "Kwik Grip" contact adhesive. It stretches a lot, so is easy to wrap neatly around sharp mandrel bends.
It's a tar based product on the back of the foil so you would lots of smoke, then a fire so as posted before DO NOT PUT THIS ON EXHAUST PIPE, please!!
It is fine for inlet and protecting against radiated heat.
  • 1 month later...
No, just going by feel. the tubing was too hot to touch before and only gets warm now. I do measure temps after the intercooler and saw a max of 36 deg in the airflow after a recent session at PI, while I have seen over 55 deg before with the stock cooler.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
