Id recommend taking the head off to save dropping a valve then having to do it anyway
This tool probably gets around this issue (dont know how it works really) but it only takes one step out of order or a quick bump etc and youll be valve fishing
I dont think its a good idea to do it with the head on with an rb because of how recessed in the head everything is. Not like a traditional rocker style setup where everything sits up higher in the head
You won't drop a valve into the engine if you pressurize the cylinder with air and have the piston at tdc. That kit has the line to pressurise the cylindr. Usualy inly 20psi is required. If it does drop due to losing air pressure etc you can lift it up again no worries with a magnet.
Having said that I don't think it would work on an rb due to the layout of the head. Why not use those hammer jobs that remove the collets? They rule.
Edited by Ben C34
For an RB sytyle you need those round tools that you press onto the retainer and magnets in the tool grab the coolers ive used that for when doing it with head on but even that tool you will need to slightly mod it as the diameter is a little to big.
Ahh yes of course. Air pressure in the cylinder. I remember now
Ive pulled a head apart out of the car at a engine shop and it was enough of a pain in the ass. Personally I wouldnt do it, id use it as an excuse to freshen upsome gaskets and clean some things up, but thats just me. Some people just want to do the job that needs to be done which is understandable
  • Like 1
Thanks for the replies guys.
Keeping the valve in place is no issue, TDC and an air compressor will work perfectly. You can also feed some rope into the bore to fill up the empty space if needed.
Removing the Valve Springs is not so much the issue, but fitting the new stronger Springs will be. Especially when trying with the "Hammer" style i.e.
Trying to push the stronger Springs down by had with that ^^^ will be a pain in the arse!
With double valve springs ive used a piece of pipe to add leverage to the arm to help push the spring lower.
Yes air and piston at TDC is the best way.
Removing the springs you wont need the tool, a well placed whack square onto a socket on the retainer is all it takes to have it all come appart.
I have seen some great tools for compressing the new springs to fit the retainers, most of the tools are model specific though, as they bolt to the cam journals. You could easily make something that would do the job I think, RB's are pretty easy to work on compared to some of the euro heads I have seen it done on.
Those Snap On valve collet remove/replace tools you've shown are the go.
Don't go feeding rope etc down the bore, just set her at TDC for each PAIR of cylinders you're working on.
Be sure to lock the crank, it will spin off TDC otherwise.
Take lots of care, no collets down oil drain holes or valve springs shot off into space.
Old valve stem seals tend to disintegrate too so watch that gunge.
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
